saph elecmirror switches? are they the same in any other car
Old Nov 24, 2006 | 03:34 PM
AJC's Avatar
AJC
Default saph elecmirror switches? are they the same in any other car
basically, the relay clicks, the mirrors dont move, could it be the switch?
do any oter ford cars use the same switch, reason i ask is that i have
mates with 100000000000's of ford bits
cheers
Old Nov 24, 2006 | 03:47 PM
dojj's Avatar
dojj
Resident Wrestling Legend
yup
it's probably something broke in the mirror but you've got to get the door cards off as teh wires run all the way down the front of the door till the bottom where the conections are
pull them apart if you like but make sure they aren't working as you need a whole miror assembly if you want to replace it
i had a few pics of them in bits, i'll see if i can find them for you
Old Nov 25, 2006 | 01:10 PM
AJC's Avatar
AJC
cheers, that be great
Old Nov 25, 2006 | 01:16 PM
dojj's Avatar
dojj
i'm taking one apart today so should be able to put plenty of pics up for you
well, when i say me, i'm not actually taken the door cards off, but someone else is for me and they can take the pics, so if they come out crap you can blame them
also, it might be worth changing the actual mirror switch as this is a lot less hassle beofre stripping the door cards off
which mirror don't work?
j.hammond1
30
Oct 31, 2021 05:28 PM
155lee
Aug 14, 2015 11:21 AM
yawiejon
15
Aug 9, 2015 06:36 PM
ray barker
Aug 7, 2015 09:00 AM
