Immobiliser light on clock fault??
Old Nov 23, 2006 | 08:39 PM
Mk5_XR3i_130's Avatar
Mk5_XR3i_130
Default Immobiliser light on clock fault??
Hi guys,
i have a fault with the immobiliser light by the clock which is flashing all the time with ignition on/engine running. but it doesnt flash with ignition off
starts and runs fine, any ideas?
car is: 1997 escort 1.8 diesel van
Thanks Matt.
Old Nov 24, 2006 | 04:32 PM
Mk5_XR3i_130
any ideas guys?
Old Nov 24, 2006 | 07:46 PM
May have a fault logged in PATS module, or dodgy signal from pick up. ?
Old Nov 24, 2006 | 08:09 PM
dave green's Avatar
dave green
As above. Try a differant key if you have one.
Dave
Old Nov 24, 2006 | 08:43 PM
Mk5_XR3i_130
ok thanks i'll try the red key, so the normal key i use could have dodgy chip?
do the faults clear with battery disconnected?
Old Nov 25, 2006 | 06:39 AM
dave green's Avatar
dave green
Thats right
Dave
Old Nov 25, 2006 | 01:19 PM
Mk5_XR3i_130
update, disconnected battery for a while then tried red key, still light off with ignition off and flashing with ignition on
Old Nov 25, 2006 | 04:45 PM
antony215's Avatar
antony215
Escort Rs Turbo
Might be the module fucked my other half had the same problem that started like your's. The light was on when the car was on then went off when you turned the car off it was like this for ages then one day it would'nt start at all i disconnected it from the module and is started stright up so like i say might be your module on it's way out If you do disconnect it your alarm wont work at all so might be worth getting another module and trying that if you need the alarm to work if you aint got an aftermarket alarm fitted
Old Nov 25, 2006 | 10:20 PM
Mk5_XR3i_130
thanks
its a van so just an immbiliser it has
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 24, 2015 11:11 AM
Flatlinedan
Sep 18, 2015 12:41 PM
The Enigma
Sep 12, 2015 10:12 PM
