hp cvh oil pump mod ?
dont you want a high flow pump as all a high pressure one does is flow the oil quicker so it doesnt cool as well. a high flow one cools a bigger amount of oil. or am i talking bollocks
what sort of oil pressure should you see at idle when warm?
reason i ask is i have a high pressure oil pump and i wondered if my oil pressure is too high...?
i have a huge oil coller from a rotary turbo
i simply took about 10mm off an old spring and upped my pressure by about a bar by adding it in , works alright
have to be careful here , too much pressure will lead to the seals on the turbo popping
better higher than lower!
so say your pressure was slightly down for what ever reason, ( the pump is fine so im wondering if its the shite gauge)
could this mehtod be yused to return it back to what it should be?
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
