which stage 3 chip?
i have a l8 ecu on my 4x4 93 and would like to upgrade to a stage three conversion,i have a t34,rs500,blues. what would be the best chip? what is closed loop? msd or ahmed? what power can i run?
Im running an MSD chip with closed loop.
Not sure what power blues are good for, you might have to upgrade to at least greens.
Ive got black 'siemens' injectors (dont cost much more than greens) from MSD and running 380 bhp.
Excellent conversion but you just have to respect your gearbox and an uprated clutch is recommended.
Closed loop makes it a lot smoother lower down the rev range and extra mpg of course
I believe the ahmed chipa are also good also good but a little on the 'brutal side'. I prefer smooth power delivery !
Closed loop is only a term used to describe the continual relaying of information betwen the HEGO and the ECM and appropriate adjustments for said conditions being met, ie a lopp of constant INFORMATION & FEEDBACK/ACTION FROM ECM.
I get 28-34 MPG without closed loop, 2wd cossie.
Originally Posted by dilo_attax
why you wanna change you chip, its gnna fuk up ! shud be happi with the power yo u gt! or ive got a "orange chip" with 300 texts if thats any good! lolz
what about Collins ??
I've been running a Collins st 3 chip and setup for about 10 years and it's been perfect...doing 336 bhp at 5778 rpm and 438 nm at 4906 rpm (above 400 nm from 3700 to 5850 rpm) at a rolling road tuneup recently.... and Im doing 9,4 to 10,5 km pr L fuel when driving "normally".... so I'm quite happy with that
The problem is 2wd is your chip was mapped on fuel back then which was not as good as we got now
so with todays fuel you can run more timing for more power and boost which makes it a more drivable car!!!!
And better fuel econmy which helps
and the fuel econmy is quite good as it is ...comparede to other st 3 cars here in DK......and yes there are some MSD cars
but that said, ... I have been thinking about a upgrade to greys again .... and just maybe I will try MSD....if I can find the last cuople of ŁŁŁ
Thats what i've gone for MSD closed loop greys and coilpack
I think its very good and hat off to stu and kenny for making greys fuel right on tickover
Used to run a level 6 and it was overfueling big time !!!!!!!!!!!!!
I think its very good and hat off to Stu and kenny for making greys fuel right on tickover
And what are your spec's and approx power/torque ?
std comp,T34.63,coilpack,escos chargecooler...
Would hope to see around 380+bhp @ 28 psi held
But i'm building another eng so should have lower comp
im peaking at 30 and holding 28 as per msd setup
uhmmm.. *thinking*
I do have a decent headgasket!
you need injectors that will flow enough fuel all the way through the rev range and needs to be setup by someone that knows what they are doing
im peaking at 30 and holding 28 as per MSD setup
if you are in the midlands which i guess you are, best speak to uncle Karl at NMS
although i have heard of NMS setups on T3's that will kill gearboxes!!
as mine is the only 1 out of 5 that hasnt killed the box
ok. So a Cometic "wrc" type should be ok then ..?
Tom, My saff runs arp stud and nut i used a cometic 3 layer gasket but it was the early type and failed..
So i now use GRP A gaskets due to them being cheaper
cos imo re-useable ones cannot be re-used
Cometic gaskets are good cos there thicker and drop the comp ratio a little
i've been advised that when running big boost on std head bolts re-new the bolts one at a time after 6k you will have no probs
Mc5506
Oct 5, 2015 09:57 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
