Cosworth engine blowing out gaskets
Old Nov 22, 2006 | 09:35 AM
Jamo's Avatar
Jamo
Default Cosworth engine blowing out gaskets
Since having my cosworth setup a few weeks back and running more boost I have been having problems with blowing out gaskets, first the cam seal gasket now the sump gasket has gone all within about 500 miles. The car has a fairly big Phil Alloy breather system on which is almost new. Is there anything that could be blocked I could replace? Or any type of test that can be done?
Thanks
James
Old Nov 22, 2006 | 01:01 PM
Jamo's Avatar
Jamo
Well I have spoken to a few people and as the engine doesn't breath any oil, oil pressure is fine just under 60psi when warm and it doesn't use any oil (apart from when it leaks) I am going to go ahead and get the sump gasket changed so touch wood its just old gaskets/seals, if It does pop another one I think it will be engine rebuild time.
Old Nov 22, 2006 | 01:33 PM
davidnormanuk's Avatar
davidnormanuk
60 PSI when warm sounds high. Not much experience with cosworths though but I'd of thought it would be around 40 psi when warm.
Old Nov 22, 2006 | 01:49 PM
Jamo's Avatar
Jamo
Hi David
Thanks for your reply, Im no expert either but from what iv been told 40psi is on the low side and 60psi is very good.
Edited to say this is when driving not at idle.
Old Nov 22, 2006 | 01:54 PM
davidnormanuk
What oil are you using? Are you using a standard oil pump? My RST runs at 60 psi when cold and 40 psi when warm I'll ask my mate with a cosworth what his runs at?
Dave
Old Nov 22, 2006 | 02:04 PM
davidnormanuk
This is what my mates is running.
about 80psi cold idle
40psi hot idle
60psi @ 2500 rpm hot
Dave
Old Nov 22, 2006 | 02:25 PM
Jamo's Avatar
Jamo
Thanks Dave about the same as mine then.
Guess time will tell see if it leaks any more oil out!
Old Nov 22, 2006 | 02:26 PM
davidnormanuk
Apparently cozzies are known for leaking oil. Are you putting any sealer on the sump gasket?
Old Nov 22, 2006 | 02:32 PM
Jamo's Avatar
Jamo
yes im not doing it though.
Its not he fact I have an oil leak that worries me more the fact it has caused two oil leaks since turning the boost up in less than two weeks.
Old Nov 23, 2006 | 11:54 AM
Jamo's Avatar
Jamo
Anyone else have any thoughts on this? Im picking the car up today from having that gasket done.
Old Nov 24, 2006 | 07:38 PM
NEWTON's Avatar
NEWTON
Originally Posted by Jamo
Hi David
thats right then
Old Nov 24, 2006 | 09:01 PM
rapidcossie's Avatar
rapidcossie
its the higher boost that gives the normal seals a hard time...
i find it impossible to keep my engine leak free..
2.5 bar does funny things to seals lol
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
