FUEL PUMP RELAYS????
Old Nov 22, 2006 | 07:22 AM
kirky's Avatar
kirky
Default FUEL PUMP RELAYS????
Was just wondering where to find the fuel pump relays on my 2wd saph and what colour they are just so i can check what the voltage is because the fuel pump has only 10.35 volts going to it! all the wireing has been renewed at the pump with new genuine connectors and wireing fitted (soldered up properly to) Was told that there is supposed to b 12volts and above at the pump????? cheeRS for any help!!!
Old Nov 22, 2006 | 10:07 AM
jon@work's Avatar
jon@work
behind the glove box - the engine management relays should be yellow
with the engine running you should be getting more than 12V
to rewire the pump, run a new fused wire from the battery and use the original feed as a switch for a new relay mounted in the boot
Old Nov 22, 2006 | 10:09 AM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
Its the one next 2 the ecu in the loom, if my memory servs me rite i think its yellow.
Old Nov 22, 2006 | 03:48 PM
kirky's Avatar
kirky
there are 2 yellow relays behind the glove box!!!
Old Nov 22, 2006 | 09:07 PM
CosKev3's Avatar
CosKev3
Yellow relay with yellow plug is fuel one IIRC
PM SECS or Ryan,both helpfull when it comes to cossie wiring
As said above though,you really need to run new wires from the battery to the fuel pump,I put new positive and earth from battery to pump
Use the original positive wire that goes to the fuel pump to switch on a new relay that you fit in the boot area somewhere,do a search on here,plenty of topics on it
The wiring degrades between battery and original relay,so this is why you should put new/stronger wire direct from battery
Old Nov 23, 2006 | 06:24 PM
kirky's Avatar
kirky
Cheers for the help! Will get it rewired
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
