Any electricians here? need some help (with Pics)
Hi everyone,
Bit of background : I have put a double switchable outside socket which i spured off the outside power supply to the garage.
This socket provides power to my deck lights, which i have to switch on by going outside flicking the switch to 'on'.
I decided to try to make the deck lights switch on from the inside, so i thought i would link the power suplly to a switch inside the house.
A pic: wire from power supply to inside the house. and back into the double socket
Back of the switch
Now the problem starts:
I was going to fit a standard 1-way switch, but accidentally picked up a intermediate switch.
Now the place i get these switches are a 80 mile round trip
Back of intermediate switch:
Here's the question how do i wire up the intermediate switch so that when i leave the double socket switched on, i can switch the lights on and off from the inside. I.e be able to provide and cut the power to the double socket.
Hope this makes sense!?
Diagramatic answers would be brilliant!
Ben
Back of the switch
Ben
Originally Posted by Lee Reynolds
You cant use a light switch to switch sockets on and off mate...
Use a 20amp double pole switch. The intermediate switch could be used at a push as you are not switching a huge load. The intermediate will probably be rated at 10 amp. If you do use this then put your blues in a connector and put one brown into the top of the switch and the other in the bottom. If it does'nt work move the bottom brown to the other terminal. I'm not sure which terminal an intermediate switches to at the bottom. I would use the 20amp double pole switch though
Series 1 dry
its only switching Lcd lights so really really low voltage.
The back of the intermeddiate look like this
L1 L1
O O
L2 L2
O O
Hope thats a good enough Diagram!
Anyway its one or the other so i'll have a play in the morning and report back tommorow.
Cheers Gents
Ben
L1 L1
O O
L2 L2
O O
Cheers Gents
Ben
Originally Posted by Eagle
so why didnt you move the main box over a bit .. so the cables came into the box at the back rather than having them on show ???
The white weatherproof box is the supply so its got to come out of there first and then inside the house and back into the socket.
Ive got to tidy the wires and seal the wall (water ingress) up as the jobs only half way through.
Originally Posted by b3nle
yep, the deck lights are permanently plugged in (the socket is switchable) and the lawnmower when i can be bothered
And lee congrats on the baby mines at 30 weeks now
(first One)
(first One)
Re the socket...what im saying is ya cant really controll that socket with a light switch if ya gonna plug ya mower into it etc you need as said a fused switched spur or a double pole..
Do not use intermediate switch as it is not, on off ,its a change over switch eg possition 1 , L1 to L1 ,L2 to L2 possition 2 L1 to L2 ,L1 to L2 so if ou use this and switch it you will either cause a short or more likely change pollarity of power to lights.If you want some clever switching get to b and q for 20 quid you can get a remote control water proof external socket
.one last thing is the circuit rcd protected.
Originally Posted by Series1Dry
I did'nt realise other stuff was gonna be plugged in so i would recommend a switched fused spur mate. Why is it an 80 mile round trip ? Where the fcuk do ya live ? lol
Right i'll get on the phone now then see if they will deliver it.
right got a fused spur switch socket! 13 amp. just fitted it and it all works
was worth the 20 quid in petrol to go get it though , the roads are well quite and its mostly b roads all the way there - bar junction 13 -15 M1.
Cheers for the help chaps i'll get some pics up soon.
supr switch:
Deck lights
was worth the 20 quid in petrol to go get it though , the roads are well quite and its mostly b roads all the way there - bar junction 13 -15 M1. Cheers for the help chaps i'll get some pics up soon.
supr switch:
Deck lights
