any bmw tech people
Old Nov 21, 2006 | 03:22 PM
fordsportjay's Avatar
fordsportjay
Default any bmw tech people
hi,just bought a 535i sport v reg.
on the journey home yesterday it cut out a couple of times when slowing down(car is an auto).
engine light came on so put code reader on it and it was coming up mass air sensor and o2 sensor.
ive just got a mass air sensor for it(new)same part no as the old one,but when fitted started spluttering and missing.plugged the old one in and it was fine.refitted the new one and was smooth on idle but splutters when you try to rev it.again fitted the old one and its fine and revs up ok.
is there something im not doing as in does the cars ecu have to read the new part or something daft like that or does it sound like a faulty new part.
help will be much appreciated
jay
Old Nov 21, 2006 | 03:28 PM
Dan Cossie's Avatar
Dan Cossie
best to go to a dealer Jay tbh....i know with Volvos if you plug anything new in your have to reload the data software for it onto the ECU....pop into a dealer slip a tech Ł20quid and get them to stick in on the diag.... could be worth a try or i could be miles out
Old Nov 21, 2006 | 03:34 PM
carlo's Avatar
carlo
You will need to delete that fault codes if you havent already done so..but we see this all the time in here a cranckase breather is burst drawing air when this happens this throws up a fault for the mass air flow sensor & when fitted it dosent change solve the prob..so check all the breather lines & the cranckcase vent valves...
Old Nov 21, 2006 | 03:35 PM
fordsportjay
just spoke to the supplier of the part -they are going to send me another out tomorrow so ill try that first unless i get a defo answer either way on here.
i remember volvos being a pain when i worked at the bodyshop.
Old Nov 21, 2006 | 03:36 PM
fordsportjay
i dont think its like that as 80% of the time the car runs fine,then it will cut out when slowing down.
the new item wont allow it to rev freely but the old one will.
Old Nov 21, 2006 | 03:38 PM
carlo's Avatar
carlo
Just a suggestion when they hoses & valves burst or leak it shoes a fault for the airflow & they are expensive then you fit it & it dosent solve the prob a hose at Ł15 does
Old Nov 21, 2006 | 03:51 PM
fordsportjay
carlo-thanks mate,i have come across this before on bmw's.all the breather pipes etc look ok on this car.they are sending me another meter tomorrow to try.
Old Nov 21, 2006 | 03:54 PM
Dan Cossie's Avatar
Dan Cossie
bloody german Crap Jay hahaha will teach ya to betray the holy blue oval
Old Nov 21, 2006 | 03:55 PM
carlo's Avatar
carlo
No probs mate it happens in here all the time good luck
Old Nov 21, 2006 | 03:56 PM
carlo's Avatar
carlo
true
Old Nov 21, 2006 | 03:58 PM
Chipped UK LTD's Avatar
Chipped UK LTD
Speak with this man: 07831103030
His name is Jason and there is nobody in the UK who knows more about BMW and fault codes.
Tell him i sent you.
Old Nov 21, 2006 | 05:55 PM
fordsportjay
thanks,if the other meter doesnt cure it ill call him.
its running on the old one at the mo and on a 5 mile run coming home it didnt cut out until i was almost home and it did it once,but didnt bring the management light on.didnt do it again after that-very frustrating!
find something i really like/want and little niggles are driving me mad!
Old Nov 21, 2006 | 06:14 PM
James's Avatar
James
i would say myself it needs to go to the dealer and have the ecu told it's got a new senser fitted.
Old Nov 21, 2006 | 07:22 PM
Chipped UK LTD
The dealer cant do much, there equipment isnt the best and they dont know how to use it to its ability anyway.
You really need someone with autologic like the person i mentioned above.
Old Nov 21, 2006 | 07:25 PM
fordsportjay
does thiscar have an idle speed control valve?im thinking it may be faulty if so.
Old Nov 21, 2006 | 07:38 PM
Chipped UK LTD
Yes it does.
Old Nov 22, 2006 | 01:29 PM
fordsportjay
fitted the replacement air flow sensor today and whilst there i cleaned all the shit from around the butterfly on the throttle-seems a bit happier now and idles slightly higher,so hopefully has cured the problem now.
just waiting for my Ł250 to come back now from the dealer
Old Nov 22, 2006 | 01:31 PM
Dan Cossie's Avatar
Dan Cossie
glad ya sorted it matey
mk3ste
Oct 17, 2021 10:09 AM
Oranoco
12
Oct 2, 2015 02:18 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
