ST24 cutting out problem....................
Old Nov 21, 2006 | 12:58 PM
Brasso's Avatar
Brasso
Default ST24 cutting out problem....................
As title, when you pull up in traffic, junctions etc... recently the revs have started to dip sometimes to the point of cutting out. It runs faultlesses other than that and sometimes goes days without doing it and then suddenly does it 5 or 6 times in one journey. I dont think its weather/damp related as its done it in all conditions.
Any ideas??
Old Nov 21, 2006 | 01:45 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Find out if it only happens when the rear lights are being used, i.e. braking. If so it's an earthing prob that I had with my old Escort. One of the earth wires wasn't bolted to the body near the driver's side rear cluster.
Old Nov 21, 2006 | 02:53 PM
ballin's Avatar
ballin
ISCV probably needs cleaning/replacing
Old Nov 23, 2006 | 04:18 PM
Brasso's Avatar
Brasso
Cheers lads.
I gave the ISCV a good clean today and thought I'd cracked it but after 20 mins of trouble free driving I got stuck in traffic and it did it again.
Is there any way of testing the ISCV to see if its fooked or not?? Anyone know how much a new one is?
Or what else could it be?? Could heat be a factor when stuck in traffic? (water temp normal)
Old Nov 23, 2006 | 09:48 PM
Brasso's Avatar
Brasso
Help!!
Old Nov 24, 2006 | 09:50 AM
Brasso's Avatar
Brasso
Up. ISCV from Fords about 50 notes Need to be certain its this.
Old Nov 24, 2006 | 10:43 AM
BlueSmoke's Avatar
BlueSmoke
So it wasn't only happening with the lights being used then?
Old Nov 24, 2006 | 10:57 AM
Brasso's Avatar
Brasso
No mate, sorry was meant to say I checked that.
Old Nov 24, 2006 | 07:09 PM
Brasso's Avatar
Brasso
Up for the night shift.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
cossirob
Sep 16, 2015 07:39 PM
