Has anyone used Emerald M3D management on a V6?
Old Nov 20, 2006 | 08:16 PM
richm's Avatar
richm
Default Has anyone used Emerald M3D management on a V6?
I'm having problems trying to get a Rover KV6 up and running on Emerald M3D. They evidently do a modified version of the ECU to cope with the extra ignition and injector drivers required, and I'd like to compare the paperwork/instructions with someone else who's done it, cos I think there's something wrong with the quoted pinout/wiring.
Old Nov 20, 2006 | 08:17 PM
Jamz's Avatar
Jamz
jim galbally had emerald on his 24v saff.
Old Nov 20, 2006 | 08:29 PM
richm's Avatar
richm
ah.. good point
Old Nov 20, 2006 | 08:31 PM
Yeah jim had it.
Was "ok" but seemed to be a bit unpredictable when i was mapping on it.
Old Nov 20, 2006 | 08:32 PM
richm's Avatar
richm
did you get involved in wiring it chip?
Old Nov 20, 2006 | 08:42 PM
richm's Avatar
richm
internally there's 3 "VB027" ignition driver devices mounted on the heatsink, and 6 surface mount pcb mounted driver devices (smaller) covered with a heatsink.
3 of these smaller devices are hard-wired to the harness connector (the 6-cyl. mod i presume)
Now it would make logical sense to me that the 3 ignition drivers would drive 3 wasted spark coils (or 3 pairs of single cyl coils in wasted spark pairs in my case) and the 6 smaller drivers do the injectors..
...but this isn't how the instructions tell it...
Instructions say to wire the coils individually to 6 pins - "Ignition drivers 1-6" and the injectors in 3 pairs to "Injector drivers 1-3"
Now this means that 3 coils are driven by the smaller drivers, which I'd be surprised if are rated to do so..
Just seems to me there may be a bit of a muddle in the paperwork??
Old Nov 20, 2006 | 08:57 PM
Nope, that was all jims work i believe (hence my concern )
Old Nov 21, 2006 | 04:13 PM
richm's Avatar
richm
anyone else?
Jim???
Old Nov 21, 2006 | 04:56 PM
marco polo's Avatar
marco polo
i'm very shore that is a dave walker ecu i know he can mapp them easy
Old Nov 21, 2006 | 05:20 PM
scruffythefirst's Avatar
scruffythefirst
The manual hasn't been updated in years, best thing to do is drop dave or karl an e-mail or ring about 9.30 and they should sort it for you pretty quick.
New software is nearly ready too, mind you it's been nearly ready for 3 years
Old Nov 21, 2006 | 06:22 PM
Jim Galbally's Avatar
Jim Galbally
use injector drivers 1-3 and ignition drivers 1-3
there are only 4 of each, so you cant go sequential.
i had 2 wiring diagrams from dave, 1 was old and wrong. check 100% with emerald you have the right diagram. the pinout n the manual was spot on, but the drawn diagram was iffy
Old Nov 21, 2006 | 06:34 PM
richm's Avatar
richm
Is this the connection scheme you used Jim?
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
griffo69
Oct 4, 2015 11:58 AM
deathrider666
Sep 28, 2015 06:12 PM
