cossie fuked part deux (with pics for those interested!)
So after my compression test on no.4 showing nowt (and fearing the worst!) I found it was only an exhaust valve thank fook! bottom end got away with it as well
Should be running in no time
thanks guys!
Cant replace all valves, in the middle of movin and Proper skint!. Going to fully de-coke it, replace stem seals and a new set of lifters though . . .
Any dents in top of piston
May have just kissed the piston if overrevved and got a bit of a kink in it
Put it in a drill and give it a spin should tell u
I would deffo change all the exhaust valves though
If a head falls off it will destroy the engine and turbo...
when you say get the cutouts machined what do you mean? My pistons are like yours and dont have cutouts, just the stepped bit. Do you mean smooth them off to make sure there are no high spots which will result in hotspots?
Graham
Graham
155lee
Aug 14, 2015 11:21 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
