Most usefull gauge? Exh temp or narrow band A/F ?
Old Nov 20, 2006 | 03:38 PM
Ridgey's Avatar
Ridgey
Default Most usefull gauge? Exh temp or narrow band A/F ?
I have a not so usefull narrow band a/f gauge, was just wondering what peoples opinions were on Exh Temp monitoring.
Is it any use ???
What i am getting at is, if it were to start going up, would it suggest leaning of the fuel and pending disaster.
Or
Could Exh temp rise with no detrimental effects to the engine?
Advice appreciated, from those that actually know something through experience
Dave
Old Nov 20, 2006 | 07:55 PM
Stu @ M Developments's Avatar
PassionFords Creator
EGT.
Bin teh narrow band, almost pointless it being in the car, has no use whatsoever.
EGT getting hotter than NORMAL will indicate either retarded spark or leaned fuel.
Exceeding 850C flat out in 5th is a a pretty bad thing period, exceeding it in any other gear is normally an extremely bad thing period. lol
Old Nov 20, 2006 | 07:58 PM
No car should ever have a narrow band gauge unless you want to check closed loop is working.
Its utterly useless for anything else!
Old Nov 21, 2006 | 10:40 AM
Ridgey's Avatar
Ridgey
Oh...
thought the narrow band might be going up for sale and a new purchase on the way.
STU, you say exceeding 850ish is bad. What would a typical operating temperature be for a stg 1 cos?
cheers
Dave
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
