cold start
Old Nov 19, 2006 | 07:00 PM
THE RADMAN's Avatar
THE RADMAN
Default cold start
when ever it gets round to this time of year the wifes 1.8 focus struggles to start ,normally it fires straight away but when it gets a bit colder you have to crank the engine for around 10 secs,it then manages to fire but seems to run on 3 cyl for a few secs then it settles down to normal,after this first start of the day its perfect again and will start instantly till its been stood o/night again,its as if some cold start sensor isnt working,any ideas chaps?
Old Nov 19, 2006 | 07:17 PM
Shins's Avatar
Shins
Only thing I can add is that with the FRS, the old AE map had amongst other things a cold start issue, this was irradicated with a newer AF map but not sure about the normal Focus!
Old Nov 20, 2006 | 07:07 PM
MATT222's Avatar
MATT222
theres loads of updates for focus the only problem is you will have to book into ford should be about 1 hrs labour
Old Nov 22, 2006 | 05:12 PM
THE RADMAN's Avatar
THE RADMAN
update, the car has now started to hesitate on light/part throttle during normal driving,if you give it full throttle its perfect,the manual suggests the clutch pedal sensor, how does that work/ what does it do? its only a 5 min job to change it,but id like some info
Old Nov 22, 2006 | 09:29 PM
MATT222's Avatar
MATT222
the clutch pedal sensor is used to flair the revs between gear changes, it's supose to give a better smoother gear change!! i would see if there are any fault codes first before chunking money at sensors that are working fine hope this helps
Old Nov 23, 2006 | 05:57 PM
THE RADMAN's Avatar
THE RADMAN
cheers for thaT
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
