Cometic head gaskets
Just a info question.
Anyone running this gasket had a prob with oil weeping.
Just rebuild my cossie long stud t4.8inj.
No leaks for 200miles but now oil weeping all around the underside
off the head gasket.
Was put on dry should i have used some kind of sealent like welseal?
Any ideas.
Any ideas.
Originally Posted by nik t
yep.
both skimmed and torqued down to 90flb with arp lube
I just put a Grp A one on mine even though i have a cometic headgasket.
I use a ARP stud and nut kit on mine as well
Steve.
What sequence did you tighten the bolts down with?
Also did you tighten them with a torque wrench (a decent one) and for the angle torques did you use a proper gauge?
Paul
Paul
ARP stud and nut kit is 120 lbft and i your using an early cometic gasket these had a problem as i was informed late last week as mine also went
The centre firing rings were 4 thou thicker than the outer to increase pressure around the combustion chamber but left the rest of the gasket not clamped down fully
they have now sorted this.
std bolts are fine to use also as long as there torque to spec:
stage 1 25 to 25 nm
stage 2 45 to 50 nm
stage 3 rotate futher 170 to 180 degrees
stage 1 25 to 25 nm
stage 2 45 to 50 nm
cheers fellas.
is the early gasket,so that would explain it.
got the new one start pulling it apart tonight.
i found my head was fooked aswell when idone mine last week
Mc5506
Oct 5, 2015 09:57 PM
