Aquamist question
Old Aug 30, 2004 | 10:08 AM
righthooker's Avatar
righthooker
Default Aquamist question
As above ,how do they work is it that they come in at a certain temp
Could some kind person please give me a quick lesson on how it works
Old Aug 30, 2004 | 10:11 AM
Oranoco's Avatar
Oranoco
The kit I'm using uses a boost switch that activates the water injection onces a predetermined boost point has been reached. The water injection is only in operation when the car is running above this point.
The more complex kits are mapable and can also have ACT parameters added in so say they will only operate onec a predetermined boost point has been reached and when ACT's are above 40deg
HTH
Old Aug 30, 2004 | 10:13 AM
Ginge !'s Avatar
Ginge !
just finding my feet
steve can ya get another that sprays water on the car at a per determined boost level so ya stop and wash it
Old Aug 30, 2004 | 10:14 AM
Jasesapphy's Avatar
Jasesapphy
Im after water injection, i will run off a boost switch as well with a tank in the boot
Old Aug 30, 2004 | 10:15 AM
Oranoco's Avatar
Oranoco
Yeah yeah! Cheeky fooker. Just washed it actually. Hooverd, cleaned the mats, polished the dash and even wiped round the engine bay just for you
Ginge !'s Avatar
Ginge !
what ya removed me name
did ya find the date mark though
Old Aug 30, 2004 | 10:17 AM
Ginge !'s Avatar
Ginge !
theres gonna be a comp soon to see whos got the dirtest car, my crystal blue ( ) cabrio will be close but ill start engraving the trophy now
Old Aug 30, 2004 | 09:08 PM
righthooker
Oranoco, cheers is that the S1 kit you have then
would you say it dose the trick mate
Old Aug 30, 2004 | 09:14 PM
Oranoco's Avatar
Oranoco
I've got the Aquamist basic kit. Not exactly sure of it's model number. I got it to help out my mini Pace interwarmer and yes it did make a difference. Mine is set to come in once 14psi has been hit.
Since the fitting of my big Pace intercooler I've not really had to use it but with it on I am yet to experience an ACT above 25deg even in the scorching sun flat out
Is worth pricing the cost of the kit against a larger more efficient intercooler though.
Old Aug 30, 2004 | 09:39 PM
righthooker
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
