2wd Cossie ACTING STRANGE
Old Nov 15, 2006 | 08:32 PM
marky boy's Avatar
marky boy
Default 2wd Cossie ACTING STRANGE
Need perhaps a few ideas or some advice on this .....
start up the car no problem:
1st thing that happens is after 30-40 sec of driving , central locking keeps locking then unlocking non stop for about 10secs
2nd after about say 5 mins of driving then car , lights start dimming in dashboard and headlights slighty
the car has just been fitted with new alternator and battery, so any help on this would be great as now a little confused
Old Nov 15, 2006 | 09:12 PM
Alvyn's Avatar
Alvyn
c/locking must be 1 of the 4 c/l motors is sticking!
alternator belt slipping possibly or the voltage regulator(back of clocks iirc) not working properly!
Old Nov 15, 2006 | 09:57 PM
CosKev3's Avatar
CosKev3
As above,could be motor sticking on central locking,could also be a wire going to the central locking in a door breaking down,probably in the rubber boot/grommet that wiring passes through to get to door
Drop me an offer via PM if you need central locking motors,got a full set of 2wd Saph Cos ones
Check all earths under bonnet and on battery/engine are clean
You really need to check the voltage at the battery when the lights go dim to see if its altenator thats faulty,has your altenator got the heat shield on the back?????
Melted the regulator on my re-conned altenator with the heat from manifold/turbo
Was showing over 16 volts on my volts gauge in car
DixieTheKid
11
Jun 6, 2020 11:20 AM
mark r
Sep 29, 2015 07:27 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
