focus 1.8 gear selection problems
Old Nov 15, 2006 | 12:29 PM
rence's Avatar
rence
Default focus 1.8 gear selection problems
Hi people
my focus has developed a problem.
It seems to be increasingly hard to get it into gear, when its warm it doesnt seem as bad and also when putting it in reverse it always crunches.
I think the bite point is slightly lower than it used to be but the clutch doesnt slip at all.
I remember reading somewhere that the flywheels can be a bit dodgy on them, is this true?
I will no doubt take it to a garage but i dont want to get ripped off and pay for a new clutch if its not the clutch at fault.
Any help would be most appreciated.
Cheers.
Old Nov 15, 2006 | 07:45 PM
dave green's Avatar
dave green
sounds like the clutch to me. and or the hydraulic slave cylinder which should be replaced at the same any way.
Dave
Old Nov 16, 2006 | 07:09 AM
rence's Avatar
rence
Is it worth changing the slave cylinder without changing the clutch to see if it cures it?
I thought the clutch would slip if it was worn out.
But the car has done 75000 miles now so i expect it will need doing soon.
Cheers.
Old Nov 16, 2006 | 08:00 PM
dave green's Avatar
dave green
its not worth taking out the gearbox unless you are changeing both.
if the clutch is woren out it will slip. if the pressure plate is faulty it will drag
Dave
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
