what will be on our cars in the future?
Old Nov 13, 2006 | 10:33 AM
GARETH T's Avatar
GARETH T
Default what will be on our cars in the future?
i was in a new S class on saturday and it got me thinking,,,
what new toys will be coming on cars in the near future?
to get the ball rolling,,,,electrical brakes
electronic wedge system
Old Nov 13, 2006 | 10:34 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
fook that, what if the fuse blows
Old Nov 13, 2006 | 10:35 AM
SapphyMike's Avatar
SapphyMike
you crash
DUUUUHHHH
Old Nov 13, 2006 | 10:44 AM
rsnissan's Avatar
rsnissan
Default Re: what will be on our cars in the future?
we have these in London already..........called cash points you just need a cash card
Old Nov 13, 2006 | 10:49 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Seems but yet again, just more electronic gizmos to go wrong
Old Nov 13, 2006 | 10:52 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
1. Pneumatically operated valves (needs 42v electrical system), for CONSTANTLY variable valve timing .
2. Variable compression ratios (do a google search for the Saab idea ).
Old Nov 13, 2006 | 10:53 AM
Stu @ M Developments's Avatar
PassionFords Creator
Those brakes are allready on teh new Mercedes.
We cant change teh pads easily as with the engine off teh brakes are locked on by the ECU. We need to tell the ecu to release the brakes so we can do a pad change and currently that requires a Mercedes computer.
Old Nov 13, 2006 | 10:54 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
Porkie's Avatar
Porkie
completely different system Stu...
Fabulous system. Currently ready for production cars i believe.
Old Nov 13, 2006 | 10:55 AM
How do you mean sir? I am talking about teh elctronic handbrake at teh moment, although i expect gareth has heard of some far more complex system knowing him.
Old Nov 13, 2006 | 10:56 AM
CossieRich's Avatar
CossieRich
Stu,
What makes it a fabulous system. I have no idea how it will even work. Obviously you do, so lets hear your thoughts mate
Old Nov 13, 2006 | 11:00 AM
Mike Rainbird
Caraholic
With no cams, you can tell the valves when to open at ANY rpm point. This means you have the PERFECT valve opening point at EVERY single RPM point. Obviously means the engine is efficient at EVERY point as it would be at it's BEST point with cams... More power, everywhere (apart from it's original peak) and better fuel efficiency .
Old Nov 13, 2006 | 11:01 AM
JTECH James
Passion for Fords!
it would mean the valve duration/lift wouldnt be determined by the camshaft..... and could be controlled by ecu
Old Nov 13, 2006 | 11:02 AM
GARETH T's Avatar
GARETH T
How do you mean sir? I am talking about the elctronic handbrake at the moment, although i expect gareth has heard of some far more complex system knowing him.
yes mate,,, completely electrical braking systems
mike ive seen the camless engine ideas,, they look amazing, and also read that bmw says they need 2kW of energy for them to work
the variable compression engine is also intresting,,,,, but a hidge on the block,,,, would be hard to keep it strong,,, even worse once we start winding loads of boost in
JTECH James
Passion for Fords!
ahh too slow
Old Nov 13, 2006 | 11:03 AM
SapphyMike's Avatar
SapphyMike
no more cam belt failures
JTECH James
Passion for Fords!
imagen that on a yb
Old Nov 13, 2006 | 11:05 AM
SapphyMike's Avatar
SapphyMike
also, as a caveat, seems to may be expensive if it fails?
GARETH T's Avatar
GARETH T
when the cams has gone,,, the spark plugs will be next
Old Nov 13, 2006 | 11:07 AM
Mike Rainbird
Caraholic
You talking about the new four rota engine? I was saving that for later .
However, as you mentioned it - after you sir .
Old Nov 13, 2006 | 11:09 AM
GARETH T's Avatar
GARETH T
i did know what your on about mike but once you have no cams,, they will run the engines on self ignition like a derv engine! made also easyer with ion sensing equipent,,, which i think the new M5 is using
Old Nov 13, 2006 | 11:11 AM
CossieRich's Avatar
CossieRich
So an engine as we know it will sonn cease to exist. they gonna do away with the pistons as well next then will stick with my age old YB set-up thanks very much
Old Nov 13, 2006 | 11:12 AM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
interesting thread
so how do the electonic brakes work then
Old Nov 13, 2006 | 11:17 AM
xr4x4rs's Avatar
xr4x4rs
engines without pistons have been around years
the good old wankle engines
question on them anyhow, how do you lower the compression on them to fit a big turbo or can you just get away with a big turbo , injectors and ecu etc
Old Nov 13, 2006 | 11:22 AM
GARETH T's Avatar
GARETH T
Originally Posted by DUDE_SWEET_FRST
interesting thread
being honest,, i dont know,,, ther is a actuator of somekind driving a wedge to create your clamping force
Old Nov 13, 2006 | 11:27 AM
Mike Rainbird
Caraholic
Not ones without spark plugs .
The Photodetonation Quasiturbine is quite similar to a rotary engine, but it has four faces on its rotor, rather than the usual three.
Photodetonation is a term for the compression-only ignition and combustion of a petrol/air mixture rather than the spark ignition of a traditional petrol engine. Petrol has a higher octane rating than diesel and is more difficult to ignite via compression alone. A conventional piston engine design would not be able to cope with the stresses, but the Quasiturbine apparently can. One of the benefits is a very clean exhaust as almost all the hydrocarbons are burnt . So this will obviously be pursued for ecological reasons...
Old Nov 13, 2006 | 11:38 AM
GARETH T's Avatar
GARETH T
good call mike
http://www.futureenergies.com/print.php?sid=32
Old Nov 13, 2006 | 11:44 AM
_DAN_'s Avatar
_DAN_
Yoon
I remember years ago hearing about a electronic-esqe valve system by Lotus IIRC.
Anyone else remember that or am I talking shit again.
Old Nov 13, 2006 | 11:45 AM
GARETH T's Avatar
GARETH T
no mate,, i remember aswell,, im sure it used valves from the shuttle on it something like 15k a piece
Old Nov 13, 2006 | 11:48 AM
R4N SS's Avatar
R4N SS
Andy, give it time mate, this type of ground breaking technology takes its time getting over to Wales they will think its the best invention since sliced bread....if they get Hovis that is
Old Nov 13, 2006 | 11:49 AM
_DAN_'s Avatar
_DAN_
Yoon
Phewww! Thought I was wrong or summant.
All I could find from a quick Google.
http://www.all4engineers.com/index.p...61e59953033163
Old Nov 13, 2006 | 11:57 AM
GARETH T's Avatar
GARETH T
what bread that is sliced??? fuck off,, thats amazing
Old Nov 13, 2006 | 12:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
42v is unlikley to happen, so camshaftless engines may have to wait a while until they go into production. of course there are companies that have them already as research engines - the carrot crunchers at lotus included
electric brake calipers enable far more braking force overall by individually apportioning maximum retardation to individual wheels - even those that are turned - and by allowing more bias to the rear than is currently used.
on the subject of brakes, carbon discs will increase in use
how about delphi's twin disc system? twice the braking torque in the same diameter package - ideal for the old skool 13"
in my area, there are already hybrid a/c compressors that have one mechanically driven scroll compressor, and one electrically. honda have been using these a while, and other companies are looking into it. means a/c can be run when engine is not running.
of course the next major step in propulsion will be hydrogen fuel cells, but i think that there may be more hybrid diesels first. i've already seen many hybrids designed for the Ultra Low Carbon Car challenge including citroen berlingo and smart forfour and fortwo. bizarre watching them drive silently about on electric power
alternative fuel engines will be more common, particularly biofuels
Old Nov 13, 2006 | 02:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you alrerady get 2 capliers braeks on the rollers (and on some bttx cars from ages ago ( ithink it was aflahpa from 95?) and electronic brakes area already is use on buses, bu they are called retarders and operate on teh gearbox, some buses have 2 stage retarders and this savess on the brake pads too
Old Nov 13, 2006 | 03:02 PM
american's Avatar
american
baseball and apple pie
....it's what makes time travel possible.
Old Nov 13, 2006 | 03:21 PM
Phil's Avatar
Phil
Jeebus
I think my dads Lexus hybrid already has this, I was wondering how the AC works when the electric engine is being used!
Old Nov 13, 2006 | 04:08 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Phil possibly, or it could be a purely electrical compressor. i don't get to see much of what the competition are doing
Old Nov 13, 2006 | 05:04 PM
aduz's Avatar
aduz
the s class is gadget heaven..my old man has placed his order for the S65 AMG
Old Nov 13, 2006 | 09:53 PM
GARETH T's Avatar
GARETH T
amazing machine mate,, sadly the one i was in wasnt a AMG,, but a great car all the same,
