weber alpha mapping software
is this readily available? theres a webber alpha ecu and loom come upfor sale on another site i use and it seems like a bargain, but i dunno about getting the software to map it?! anyone shed any light on the subject?
The Weber stuff is very good, after all Colin Macrae has it on his MkII Escort
BUT.... you can only take it to a Weber approved centre to have it set up and there are only a few around the country.
Not a bad product at all, just short sighted of Weber not to make their mapping software available to people.
Depends on how much you want to dick with it once its set up really and how far you want to travel to get it set up.
If the unit itself is cheap then it may be worth putting what has been saved towards getting it set up.
Dont let people tell you the product itself is shit as its derrived from the production car ECU's that Weber Marelli were doing like the Cossie ecus... in fact the early units came in the same box as the Cossie ECU's.
Also make sure the unit is a newer type that can be mapped with windows, the DOS based ones are a pain in the dong to map as it take so long up loading and downloading changes.
nah not worth it then, i intend on doing the mapping myself with the help of a mate, so if i cant get the software then its a no-go. it was £250 quid for the ecu loom and sensors, not worth the agro when i can get a V3 megasquirt for 280 or whatever they go for.
sridgett
Oct 1, 2015 07:30 PM
