Problems with polybushed rear wishbones...... anyone else?
Old Nov 11, 2006 | 05:11 PM
RST_mark's Avatar
RST_mark
Default Problems with polybushed rear wishbones...... anyone else?
I've got Deflex poly bushes fitted to the rear wishbones on my S2 RST and have noticed they have a great deal of play in them
They've been on the car about 2 years and i fitted them when the car was apart being restored.
Basically i removed the rubber section of all 3 bushes which left me with the outer metal ring. when i tried to fit the bushes there was no way the polybushes were going to fit so i rang deflex and they told me to remove the metal rings all well, which i did and the bushes then fitted.
Now because the bushes only have a small surface area against the wishbone itself this is allowing the polybush to flex and a lot of movement on all 3 mounting points.
Has anyone else had this problem or any advice they can give me. Tried calling Deflex but cant get no answer.
Think i'm gonna have to get some other wishbones and start again
Cheers, Mark
Old Nov 11, 2006 | 06:48 PM
mercury grey minter's Avatar
mercury grey minter
Had this problem with mine.You need to leave the sleave off the old bush in place.I had to burn my old bushes out so old sleave was FOCKED.Tried to fit my new DEFLEX ones ,but as you said "TOO MUCH PLAY".I sold my DEFLEX ones on E-BAY and got POWERFLEX ones.But then heard that DEFLEX have now sorted this problem by making a sleave you can buy to take the play out of your new DEFLEX ones.Give them a call.
Old Nov 11, 2006 | 07:38 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
First mistake, going for the cheeper option. . altho Deflex do make some bushes that fit
Old Nov 11, 2006 | 10:33 PM
addiction's Avatar
addiction
i've got deflex all round and have had no problem with them in the 3 years they been on the car
Old Nov 12, 2006 | 01:39 AM
vroooom ptssssh
It Wasnt Me!
No, their wont be any problems with the bushes once fitted. . ive just heard of allot of bushes not fitting, too small.
Old Nov 13, 2006 | 10:06 AM
RST_mark's Avatar
RST_mark
Cheers mercury grey minter, i removed just the rubber part to start with but couldn't get the new ones in so was told to remove the metal too. Will give them a call and hopefully they can sort me out with some sleeves or else i'll try and get some made up.
any one else had the same trouble?
Old Nov 13, 2006 | 05:25 PM
RST_mark's Avatar
RST_mark
Does anyone know if Deflex are still open for buisness or have they got a new number as i can't get through to them.....
Old Nov 13, 2006 | 07:23 PM
JesseT's Avatar
JesseT
The old bushes where supposd to be fitted without the metal sleeve, which obviously never really worked. The new ones are smaller I presume to fit inside the old bush's sleeve. I myself welded some extra tubing to make more contact area.
Deflex are in the process of moving their factory which will cause some delays (as if there weren't before). It's rumored that they will be back with another name when they get the new factory going. Actually YOU should know as it's a UK thing.
Old Nov 14, 2006 | 05:35 PM
rswoza's Avatar
rswoza
i did teh same just welded in a strengthening gusset..... mine were powerflex but they were old ones like the deflex design.... wether the new powerflex ones are still like it i dont know
Old Nov 15, 2006 | 10:15 AM
RapidRS's Avatar
RapidRS
The first ones they sent me for the wishbones for my old XR3i were too big and didn't fit inside the metal sleeve, phoned them up and they sent another set which fitted perfectly. Top banana!
(Still have the bigger ones if anyone wants them...lol )
Old Nov 15, 2006 | 07:43 PM
RST_mark's Avatar
RST_mark
Funny you should say that RapidRS, if i could have the bigger ones you still have that would be ideal as mine are damaged beyond use now as using them without the sleve. PM sent.
Cheers for all the info.
Old Nov 15, 2006 | 08:15 PM
RapidRS's Avatar
RapidRS
Mark, you have PM.
JoeyBoyden
Jan 4, 2024 02:36 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
3drRich
Sep 13, 2015 07:32 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
