3dr power steering pipe
Old Nov 8, 2006 | 05:17 PM
B11GNS's Avatar
B11GNS
Default 3dr power steering pipe
The pipe which goes from the bottom of the reservoir to the pump (the fat one) doesn't go directly to the pump, it sort of bends up, goes in a loop then goes back down to the pump (dont know if its the same on the saphs). What i want to know is does this pipe have to be this shape or could i fit a pipe which goes directly down to the pump. I'm asking as the pipe is no longer available from ford
Old Nov 8, 2006 | 09:23 PM
CosKev3's Avatar
CosKev3
Not sure if its the same as 2wd saph,but I bought a saph one last year from Ford m8
Needs to be special hose for power steering fluid though,very corrosive apparently
I rang Roose Motorsport when doin mine,he couldn't supply anythin to do the job
Old Nov 10, 2006 | 02:34 PM
B11GNS's Avatar
B11GNS
Yep, it is the same as the 2wd saph and have checked at fords and it is no longer available
Old Nov 10, 2006 | 09:38 PM
CosKev3's Avatar
CosKev3
Have you got a helpfull Ford parts dept???????
Just wondered if they had done a check to see if any kicking about at any dealers anywhere in the country
Might be worth asking Doo on here to check
Old Nov 11, 2006 | 02:56 PM
B11GNS's Avatar
B11GNS
They checked at daventry and said that its no go basically.
Old Nov 11, 2006 | 02:58 PM
B11GNS's Avatar
B11GNS
I'm trying to get hold of the RS owners club as apparently they have bought up all fords discontinued parts so i'm wandering if they have got the last of them.
Old Nov 11, 2006 | 03:49 PM
Alvyn's Avatar
Alvyn
take the old pipe to any good hyraulic firm and ask them to make one up using your old connection from the original pipe!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
