my s1 keeps blowing a in line fuse that has been added to a wire off the ignis switch its a 30amp,it blows if i have my heaters,wipers,and heated rear screen on,it seems to run to the fuse box,any ideas men?
Straight away that fuse is too small to have all that running from it. I would say remove it but u dont know why its there and whats happened to the previously
Sounds like its been trying to run a hefty circuit then, trace the wiring dude see where it goes. Find where it goes in the fuse box, might be feed someone has added due to a failed circuit in the past.
