stage 3?
Old Nov 5, 2006 | 10:02 PM
MICKY84's Avatar
MICKY84
Default stage 3?
i have a 2wd sapp. i am going to fit the following:
-31, 18psi boost on standard t3, scorpion 3 1/2 inch exhaust, k&n panel filter, level 8 ecu, 4x4 tps, 4x 803 (dark greens), 3 bar map. standard i/cooler.
any ideas what bhp and torque it'll give?
do i need a oil seperator
Old Nov 5, 2006 | 10:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Re: stage 3?
About 300bhp
I would always uprate the breather system
Steve.
Old Nov 5, 2006 | 11:48 PM
Jay,'s Avatar
Jay,
Sponsor
280 bhp realisticly and the oil seperator around that psi upwards advicable but not totally nessersary
Old Nov 6, 2006 | 12:21 AM
jon@work's Avatar
jon@work
depends on bore wear
for what a breather kit will cost, I'd say that fitting one wouldn't be a bad idea
Old Nov 7, 2006 | 03:10 PM
foreigneRS's Avatar
foreigneRS
Testing the future
forget that on a std 2wd i/c in the summer. you want a 4x4 one at least.
Old Nov 8, 2006 | 08:01 AM
stonehavencossie's Avatar
stonehavencossie
the greens/ 3 bar might not be required at circa 280 bhp also
Old Nov 8, 2006 | 09:02 AM
foreigneRS's Avatar
foreigneRS
Testing the future
as above. if you are only running 18 psi on greens and a 3 bar MAP on a t3, make sure that you have a chip to suit. most will be for t34 and will overfuel like hell loosing you power, using oil, higher fuel consumption, shorter spark plug life etc.
if you only want to run 18 psi, i would see NMS about a 'gunship' setup
Old Nov 8, 2006 | 05:31 PM
MICKY84's Avatar
MICKY84
Default STAGE 3?
HI AGAIN GUYS. THANKS FOR HELP AND SURGESTIONS. IM THINKING OF GETING A 500 COOLER, OIL SEPERATER AND A T34 AS WELL NOW. MAY AS WELL DO IT PROPER OR I'LL LOOK INTO THIS NMS GUNSHIP. ANY IDEA ON PRICE OF THIS? IS IT GOOD?
Old Nov 9, 2006 | 09:55 AM
stonehavencossie
Default Re: STAGE 3?
thats the spirit, proper stage 3
Old Nov 15, 2006 | 11:55 AM
Twellsie's Avatar
Twellsie
I have a gunship conversion but running greys and 3 bar it gives 316 bhp and 346 ft/lb torque (with a 4x4 intercooler as its a fourbie)
Old Nov 15, 2006 | 12:26 PM
stonehavencossie
on a t3 ? 3 bar ?
why would you run grey at that power ?
Old Nov 15, 2006 | 02:31 PM
foreigneRS's Avatar
foreigneRS
Testing the future
think he means 3 bar MAP sensor, not 3 bar boost
it's better to use a 3 bar MAP as the ecu can then see what the boost is rather than guessing (as a gunship midrange boost is higher than the standard 2 bar one can read). by using greys (or dark greens) with that conversion, you don't have to run higher fuel pressure like you do with yellows to get enough fule flow at the higher boost (higher fuel pressure = more load on fuel pump and wiring)
Old Nov 15, 2006 | 03:33 PM
stonehavencossie
ah ok
3 bar boost lol
still dont get the greys, surely the cheaper greens would be fine
the old t3 must be right on it limit !
Old Nov 15, 2006 | 04:17 PM
foreigneRS's Avatar
foreigneRS
Testing the future
cheaper greens would be fine, but maybe he already had the greys or is looking to the future when he may replace turbo with a monster or something and only wanted to buy injectors once
Old Nov 16, 2006 | 11:37 AM
Twellsie's Avatar
Twellsie
found some greys at the right price and as mentioned will be getting a bigger turbo in the future
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
