oil cooler???
Nov 5, 2006 | 06:16 PM
oil cooler???
how easy is it to fit a oil cooler, do you have to buy a sandwich plate or can you just use the original one that the oil filter bolts to and just use the pipes from that ?
Nov 5, 2006 | 07:37 PM
Do you mean like a front mounted mocal jobby?
Nov 5, 2006 | 07:55 PM
Buy a full kit and throw your standard cooler away.
And the hoses which are connected to the standard one lead water
Nov 5, 2006 | 09:52 PM
ur rst will have one on it ant now
Nov 6, 2006 | 11:58 AM
cooler
if i remove the old cooler, what do i do with the pipes that come out of it, or are they not needed? i think they go into the engine.
Nov 6, 2006 | 12:57 PM
The 2 pipes that come off the top of the standard cooler are part of the cooling system which can be bypassed if your not using it anymore.
Nov 6, 2006 | 01:33 PM
Re: cooler
Quote:
the std oil cooler is fine why change it
Nov 7, 2006 | 05:33 PM
my car seems to run really hot under the bonnet, but the water temperature is fine. i mean if its running for a about 10 - 15 mins constant driving you could fry a egg on the bonnet and the warmer it gets you start to get a rattle. so i thought the oil might be getting to hot. ohh yeah ive just given it a oil change aswell so its new oil too
Nov 7, 2006 | 05:51 PM
well if it gets to hot you know u got trouble have you tryed a flush of the whole water system??
Nov 8, 2006 | 11:05 AM
cooler
yeah i flushed out the water system twice just to make sure, anything else you might think it could be, or is it just fucked!
Nov 8, 2006 | 11:43 AM
Have you checked the timing. If its too far retarded it will run hot?
How did you flush out the cooling system?
Nov 8, 2006 | 06:51 PM
if the timing was out would it still run ok?
Nov 9, 2006 | 07:11 AM
Yes it would. Mine ran fine but hot and found the timing to be out 2 degrees. Put the timing how it should be and no more heat problems.
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
