Heated Front Screen Relay
Originally Posted by SafeChav
Any 89/90 Escort/Orion with a heated screen or any XR2i with a heated windscreen also.
I have got a relay here but its a bit shabby looking
Just had a quick look under the dash and can only see 2 relay's one is pink fuel pump relay the other is green and is for the abs
Brian
Yes mate 1990 Escort Rs Turbo
The heated window did work but it doesnt seem to now
The light come's on when you switch it on also you can hear the relay click but it wont work
Brian
Brian
If the light comes on and the relay clicks the relay is fine! The light takes its feed from the same pin that outputs to the elements.
The heated screens are prone to stop working. I suppose you might have a broken wire.........
Have you had a meter on each of the wires at the side? Each one should have 12v (2 seperate elements)
AND.......remove the roof clock and you will find the earth strap, and also a rather annoying burn mark on the back of your clock..........
Will have a look at it using a meter
My mate's fiesta had the same prob as me and he replaced the relay and it now works fine
Dont think the screen has a broken wire........
Will see if i have 12v and will remove the roof clock and have a look
Brian
Brian
Brian
Brian
Let me know how u get on
Told ya so
Thats women for you mate
The other half said it wasnt working so had a quick look then come home yesturday and she said its working now then i went out last nighti n the car and it was deffo working lol
Brian
Told ya so
Brian
Surprised you even let her drive it
Told ya so
Brian
She use's it for work every day
I aint to fused i got my Fiesta in the garage that no one drive's apart from me lol
Brian
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
