is it my cam belt
Old Nov 4, 2006 | 08:29 AM
deankenny's Avatar
deankenny
Default is it my cam belt
ive started hearing a strange hissing noise and last noise it finally got much worseand was coming from the cam belt, but i just rang this guy up to order a timing belt kit and he said it would be the alternator belt ttry tightening that first, where would i find this other belt and how do i tighten it ??
Old Nov 4, 2006 | 10:31 AM
Alvyn's Avatar
Alvyn
down the same side alternator will have a 13mm bolt with a slide bracket undo the bolt and lever the alternator to tighten the belt abit! all the above is IF the belt is loose!
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
