top end misfire
when using my series 2 hard there seems to be a top end end misfire around 5.5 6k?
also just as of the this morning it was idling at 1600rpm!?
the car is due a good service so maybe this will sort it but a just wanted to check if anybody else had had this problem
engine spec
standard bottom end
stage 1 head
cvh 35 cam
radtec front mount ic
pace rad
unknown chip
full ss exhaust
20 psi
engine spec
standard bottom end
stage 1 head
cvh 35 cam
pace rad
unknown chip
full ss exhaust
20 psi
Roosie
Aug 13, 2015 07:40 PM
yawiejon
15
Aug 9, 2015 06:36 PM
