its just that the car i got on sat had what i delived to be a bleed valve on but no boost. repiped it to the amal valve and got boost back but its peak is 23psi
23 PSI is way too much. You'll probably need to lengthen the rod of the waste gate actuator. Or somebody has messed around with the amal valve. If you're not into that stuff it's probably best to see an expert first.
