Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
what year did brake sevos start on the mk3?
Old Oct 29, 2006 | 08:47 PM
rst in breaking's Avatar
rst in breaking
Default what year did brake sevos start on the mk3?
as above please? are they hard to fit as mine hasn't got a servo i only have a master cylinder, does this have to be moved to fit a brake servo with a zetec turbo? and whats the best brake servo to fit? cheers
Old Oct 29, 2006 | 09:39 PM
MikeyXR2i's Avatar
MikeyXR2i
It hasn't got a servo?? i thought all MK3's had servo's, i only ever seen old cortina's without servo's and you could buy kits to convert em.
Old Oct 30, 2006 | 06:14 AM
rst in breaking
its gotthe master cylinder on the drivers side and fluid bottleonthe drivers side of the engine bay but no master cylinder, i know alot of escorts are onther passengers side of the engine bay
Old Oct 30, 2006 | 07:00 PM
GraphiteGray's Avatar
GraphiteGray
What year is your car, sounds like youve got an early base model there, 1.1L maybe??
Do you have many drilled holes on the passenger side where the servo mounting brackets would be? Maybe you could pull the linkage and servo out of a mk4 RST/XR3i and fit the whole lot, you'll probrably have to get new brake pipes made up to reach it.
On the other hand if you could get hold of a servo and linkage from a LHD escort you could possibly be able to adapt that, but there could be clearance issues
Old Oct 30, 2006 | 07:02 PM
GraphiteGray
Put some pics up of the engine bay, im wondering whether an RS1600i servo could be adapted to fit as theyre bolted directly to the bulkhead
Old Oct 30, 2006 | 07:54 PM
pdb-RS1600i's Avatar
pdb-RS1600i
keep it like it is!one of the reason why the brakes are so poor on the mk3 is because of the servo and master cylinder being on the pass side with all that linkage
Old Oct 30, 2006 | 09:47 PM
rst in breaking
i guess it wouldn't make to much difference it would just make the brakes feel better with one
Old Jan 4, 2007 | 11:22 PM
SafeChav's Avatar
SafeChav
Its the very early ones only that don't have servo's, before 83 and im pretty sure its only the lesser models that didn't have them (the slow ones lol)
GraphiteGray, *i think* all the shells have the mountings, there will just be a blank plate welded in on the passenger side
Old Jan 5, 2007 | 05:10 PM
rst in breaking
cheers mate, its only a 1.1 its just mint tho, have plans for it though lol
Old Jan 5, 2007 | 10:13 PM
SafeChav's Avatar
SafeChav
Yer well if your planning putting anything bigger in you might wana get a servo
Might be a lil bit scary to drive otherwise
Old Feb 21, 2007 | 07:21 PM
Lux_Interior's Avatar
Lux_Interior
Yep its the 1.1's that didn't have a servo, and as has also been said it should have the correct drillings on the bulkhead to fit a linkeage and servo to it.
The mk4 servo mounting brackets are different, so don't go to all the trouble of taking one off a mk4 thinking they're the same!
Also, avoid the RS1600i linkeage, its not half as efficient as the standard mk3 Escy type
Bailes1992
Aug 16, 2015 07:14 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
Bosch
Aug 4, 2015 05:14 PM
