Should i remove abs?
Old Oct 29, 2006 | 12:15 AM
escortlad's Avatar
escortlad
Default Should i remove abs?
Just wondering if its worth the hassel or not?why do people take it off?I am fitting saff cossie brakes soon if that makes a differance?
Old Oct 29, 2006 | 05:39 AM
scottbrown's Avatar
scottbrown
take it off cos it shit...lol
also if it goes wrong very difficult to find parts,
have a search for a guide as its been covered a thousand times
Old Oct 29, 2006 | 08:08 AM
Brian's Avatar
Brian
Are the brake's any better with it removed??
Brian
Old Oct 29, 2006 | 09:07 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Yes - Remove.
Yes - The brakes will be better
ONLY if you do it right!!!
DO NOT CUT BELTS!
DO NOT USE THE SAME LINES
DO NOT USE THE SAME MASTER CYL
YOU NEED A NON ABS CAR AND REMOVE ALL THE LINE AND COMPENSATORS.
THEN YOU NEED TO CHANGE THE CYL RATING TO 23.
Any info you will need is here:-
http://oddkiddcreations.co.uk/forum
HTH
Regards
Jano
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
