coilovers for ERST
Hi mate,
You can get AVO which are slightly cheaper or leda which are more exspensive, i am led to beleive that the Leda's need the rear suspension turrets modding quite a bit (all relative) and that the AVO units bolt in, they are however i am led to beleive slightly infieriour units but again relative
Ledas you can get from Mike Rainbow and i am sure he could also get you AVO's but you could also contact them direct
Hope that helps
Mike
Hope that helps
Mike
Nope but am looking into it,
I beleive AVO's in the region of 450 pounds and Leda up to a grand
Like i said i know that extensive rear turrets mods are needed for the Ledas definately so you really need to ask if you think they are worth it
Mike
Mike
I run Bilstein Coilovers all round.
NO modifications are needed for either front or rear as these have been developed and are manufactured by us to fit. The only bit we import is the Bilstein insert from Germany.
Priced at £250 each or £995 for the full set. (For 4 Leda's I believe your looking at around £1400)
Depends on what you are going to do with the car at the end of the day as to what sort of quality and price you want to pay.
Tony
Tony
Mc5506
Oct 5, 2015 09:57 PM
