how to fit other ford wheels
Old Oct 28, 2006 | 03:00 PM
marky_g's Avatar
marky_g
Fleet Manager
Default how to fit other ford wheels
as above i no the later shape ford wheels have larger holes where the wheels sutds go becase of the nuts used of later cars
is there a comon way around fittilg later shape rims
E.G. mondy 16's 5 spokes
without daoing a hub conversion.....longer or bigger bolts?????
see alot of motors driving aound of diamond cut rs 7's ect just wondering
Old Oct 28, 2006 | 03:03 PM
addiction's Avatar
addiction
you can either buy new bolts with the correct fitment on them or you can just buy the washers. grayston,demon tweeks,speedshack or any alloy wheel dealer will sell them. i got mine from speedshack
Old Oct 28, 2006 | 03:12 PM
marky_g's Avatar
marky_g
Fleet Manager
fookin mint i'll be doin thet washer thing
how much were that mate???
Old Oct 28, 2006 | 03:21 PM
marky_g's Avatar
marky_g
Fleet Manager
im gonna call speed shack what do i ask him for????
Old Oct 28, 2006 | 05:16 PM
NIMRODS_RST's Avatar
NIMRODS_RST
MISSING MY RST!!
had no problems fitting 16" mondy rids on mine
Old Oct 28, 2006 | 09:17 PM
addiction's Avatar
addiction
just tell them what your trying to do and they will know what you want. they were very helpfull when i got my bolts
Old Oct 29, 2006 | 09:08 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
BOLTS ARE SHITE!!!!!
Replace them with studs. Safer and easy to remove and refit wheels etc..
Regards
Old Oct 29, 2006 | 05:46 PM
marky_g's Avatar
marky_g
Fleet Manager
jano do u sel the kits then???,
its only to fit a set of escort rs2k rims (there like 15's) on my darily driver, dont wanna mess about with hubs etc
Old Oct 29, 2006 | 05:54 PM
project rs's Avatar
project rs
hi lads i'm just about to try the conversion to studs. i've got the studs ready to fit i'm thinking you only need to drill the holes out to 13 mm then fit the studs from the rear till fully tight, then i was going to put a tack weld on them as a added precaution to stop them from moving does this sound right to you all
Old Oct 29, 2006 | 06:06 PM
Versus_Creations
Ask me a question!
project rs
Thats excatly what you need to do pal. Dont need to weld the studs tho.
The studs can be found at any breakers yard on most late fords. Take a hammer and use an old nut wound on the thread a few turns, then smash it
Old Oct 29, 2006 | 06:12 PM
marky_g's Avatar
marky_g
Fleet Manager
nice any perticular car to take them from????
do u tap the hole or just drill it to 13mm?????
aint the original holes bigger then 13mm???
Old Oct 29, 2006 | 06:57 PM
fatboy billy's Avatar
fatboy billy
i just have the washers on mine to put the rs7's on
Old Oct 29, 2006 | 07:33 PM
XR2's Avatar
XR2
Bolts (H&R Quicksafe kit) with the big nuts for the rims:
Old Oct 30, 2006 | 08:56 AM
Versus_Creations
Ask me a question!
Nice kit, but no way would i pay for them
Mk5/6 Escort.
Or the Transit has extra long studs if you need long ones for whatever reason.
Regards
Old Oct 30, 2006 | 06:27 PM
marky_g's Avatar
marky_g
Fleet Manager
so what about the drilling
Old Oct 30, 2006 | 07:28 PM
project rs's Avatar
project rs
hi again tried it out today and 13mm is the size needed to be drilled to. much easier to get the wheels on now no more messing around trying to line the holes up and getting the bolts in to keep it from dropping of should of done this years ago, this is the way to go mark cost me20 quid for the studs and allow an hour a corner
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
RockinRein
Aug 19, 2015 07:08 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
