uuuummmm strange one..help
Old Oct 27, 2006 | 04:46 PM
scottbrown's Avatar
scottbrown
Default uuuummmm strange one..help
right then, bought a chrome cambelt cover for my s2, I know its a rs turbo one as it has it engraved on it...
but it dont fit
everything lines up but the standard bolts are too short, the guy I bought it off on rsoc had it on an erst.
when you put it against the standard one they look identical, but the bolt is too short to catch the threaded holes on the block.
do I need diff bolts or am I just being a spastic?
cheers
Old Oct 27, 2006 | 05:35 PM
chris^si's Avatar
chris^si
i can get you some longer bolts if you want mate? some crome ones
Old Oct 27, 2006 | 06:02 PM
addiction's Avatar
addiction
just get some longer bolts
Old Oct 27, 2006 | 06:46 PM
scottbrown's Avatar
scottbrown
that would be spot on mate
scottbrown's Avatar
scottbrown
to you too
Old Oct 27, 2006 | 07:19 PM
JamboRS's Avatar
JamboRS
focus rs 1672
could you get me some bolts to mate?,ive got the same problem,my bolts just catch the first thread and no more,usually works loose after a bit of hard revvin
Old Oct 27, 2006 | 07:55 PM
scottbrown's Avatar
scottbrown
no
so its a common prob then.. I cant even get the slightest lock on them
Old Oct 28, 2006 | 12:07 AM
antony215's Avatar
antony215
Escort Rs Turbo
The bolt's from you standard belt cover won't be anygood them chrome/stainless steel one's come with longer bolt's with an alan key head when bought new.
Old Oct 28, 2006 | 10:33 AM
chris^si's Avatar
chris^si
right so then, what bolts am i getting for you scott? 8mm x how long? and the same for jambo?
Old Oct 28, 2006 | 10:34 AM
chris^si's Avatar
chris^si
oh and do you want allen or hex? i'll grab some crome washers as well
Old Oct 28, 2006 | 11:27 AM
addiction's Avatar
addiction
8mm x how long?
8mm is too big dude,if my memory serve's me correctly they are 6mm and need to be about 30mm long
Old Oct 28, 2006 | 01:13 PM
JamboRS's Avatar
JamboRS
focus rs 1672
ill get a measurement for mine later tonight,i think addiction is correctmthere about 6mm,ill know for defo later
cheers
Old Oct 28, 2006 | 02:00 PM
chris^si's Avatar
chris^si
no worries, i can do 6mm up tp 6 x 90 i think
Old Oct 28, 2006 | 03:28 PM
marky_g's Avatar
marky_g
Fleet Manager
10mm head 6mm tap u want them 30/35mm long
16p each B&Q....i got some earlyer today
Old Oct 28, 2006 | 03:49 PM
scottbrown's Avatar
scottbrown
cheers chris mate.
give us a shout mate when you get them..
cheers
Old Oct 28, 2006 | 03:57 PM
chris^si's Avatar
chris^si
should be mon eve when i get back from work mate
Old Oct 28, 2006 | 04:13 PM
scottbrown's Avatar
scottbrown
cool
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
JamesH
Sep 2, 2015 10:02 AM
