boost surge
it happens when the turbo is producing more flow than the engine is consuming! the exhaust energy starts to fall off redusing the torque available on the compressor wheel slowing it down (lowering the output flow) the compressor now starts speeding up again producing flow until it hits the same spot as earlyer (engine not consuming the flow) and it all starts again
whats the spec of your engine?
just put it back on greens ,low comp ,cooler all normal stuff 34 tybrid ,slight head work
only trying for22psi but at about 5 grand it starts to surge and back off
defo not a miss fire
should not be lean its a new MSD chip with a base idle of 3 % the car is mechanicly prity good was wondering about the amel valve jetting
ps sorry about the slow responce keyboard batterys flat and on on screen keyboard
sorted most of the poor power issue was as garath said very low co was the problem
still got the noise like a high pitch squeel
thought it may be turbo but but runs spot on when onlow boost 15psi(aprox) no noise
could it be the amal valve ?checked hoses etc
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
