zvh boost
Old Oct 26, 2006 | 04:03 PM
sy.rst's Avatar
sy.rst
Default zvh boost
iv got a 1800 zvh sat in the garage ready for my rst.i brought it second hand,it has skimmed pistons(not sure how much) any one know what boost pressure i can safely run wiv these pistons? are the spacer plates used for lowering compression any good. thanks
Old Oct 26, 2006 | 04:39 PM
320 bhp's Avatar
320 bhp
i tried 18psi on my 2 litre and melted them to bits then fitted a set of accrilites from burton power quite cheap and made it a 2.1
Old Oct 26, 2006 | 05:12 PM
gup's Avatar
gup
i was told about 10 psi was on the limits
Old Oct 28, 2006 | 10:59 AM
scotty86d's Avatar
scotty86d
on a 2 litre with the pistons skimmed enough to bring it down reasonably i was told I could run a bar if the intercooler and fuelling were good!
Old Nov 10, 2006 | 12:24 PM
Avinitlarge's Avatar
Avinitlarge
I hate the idea of skimming pistons, Im using dished blacktop pistons that have been ceramic coated with a 3mm de comp plate. On my last engine i used the same pistons but no ceramic with a 2.5mm de comp plate running 14psi with no problems
Old Nov 10, 2006 | 02:42 PM
cos jon's Avatar
cos jon
I ran 17psi on my 2.1 but it needed a bigger intercooler for any more !!
Old Nov 11, 2006 | 12:10 PM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
i have a 2litre one in the garage without the pistons skimmed but a big copper decomp joint from ferriday
rob
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
davidfordrs
Sep 21, 2015 04:23 AM
