Stupid cosworth headlight problem. please help
Old Oct 25, 2006 | 05:58 PM
Paulo P's Avatar
Paulo P
Default Stupid cosworth headlight problem. please help
Hi
I've just got my sapphire back together and the headlights are doing something strange. If I put the sidelights on the dipped beam bulbs light up too but they're dim. If I put dipped beam on nothing changes. If I then try and switch main beam on nothing happens but I can flash the main beams.
So far I've tried a different switch and a different relay but nothing has made a difference so far.
I've checked the earths behind the dash around that area and they seem ok. Everything else works perfectly on the car except for the dipped beams and mains. With the ignition off just the sidelights come on as they should but with the ignition on the dipped beams come on but not as they should.
Just put the dash back in and I was getting the correct voltage at the switch so I guess the fault is elsewhere. Where else should I look? Are there earths near the front lights?
Any ideas help or input would be greatly appreciated.
Thanks
Old Oct 25, 2006 | 07:45 PM
costina's Avatar
costina
Live long and prosper!!
Theres earths by the lights either side 10mm headed bolts,when the sides are on with ign on, these DO light the dipped beam just a little.
its called dim-dip lights
Old Oct 25, 2006 | 07:53 PM
Paulo P's Avatar
Paulo P
I didn't know that I thought just the side light bulbs would come on. I'll investigate further tomorrow thanks
Old Oct 26, 2006 | 02:10 PM
Paulo P's Avatar
Paulo P
Cleaned the earths by both headlamps and the fault is still there If I check the voltage on the brown wire and yellow wire on the back of the bulb I get 6 volts on the passenger headlight and 5 volts on the drivers one. This is with the switch in either side or dipped beam position. If I check the voltage at the plug that plugs into the lights I get 13 volts (with engine running) at the passenger side and nothing on the drivers side.
What does that suggest please?
Thanks
Old Oct 26, 2006 | 02:23 PM
IANS2RST's Avatar
IANS2RST
is the lamp failure ecu plugged in if not they won't work, also try the relay in fuse box
Old Oct 26, 2006 | 02:40 PM
Paulo P's Avatar
Paulo P
The lamp ecu is plugged in. Can these fail and cause problems?
I've checked the voltage outputs on the fusebox for relay F and I'm getting 6 volts from both pins nearest the front of the car.
Thanks
Old Oct 26, 2006 | 02:41 PM
Paulo P's Avatar
Paulo P
I've also changed the Blue relay. The brown one is the one I checked the voltage on.
Old Oct 26, 2006 | 03:15 PM
IANS2RST's Avatar
IANS2RST
the relays are white i think try these, there is normally 2 so swap them over.
could also be a problem with fuse board
if the lamp failure unit is faulty it can cause problems. mine was giving false warnings which caused problems with the rear lights so i unplugged it completely then I had no lights
Old Oct 26, 2006 | 04:27 PM
Paulo P's Avatar
Paulo P
I've just looked and there's only 1 white relay in the fusebox on mine. According to the manual the relays for the lights are the Blue 1 which is number 2 and the brown one which is relay F.
I'm wondering whether it could be the fusebox or the lamp ecu that is faulty. Has anyone changed a fusebox?
Old Oct 26, 2006 | 07:22 PM
costina's Avatar
costina
never known a saff fuse box to go wrong Paul,are u just not getting dipped beam? have u checked the light switch ???
My thoughts would be the switch
Old Oct 26, 2006 | 07:42 PM
Paulo P's Avatar
Paulo P
No dipped beam and no main beam but mains can be flashed. I have tried another switch and it was exactly the same. I have also changed the blue relay.
With the side lights switched on the sidelight bulbs light up and so do the dipped beam bulbs but the dipped beams are very dim. For some reason main beam then doesn't work and the blue light on the dash doesn't light up but if you flick the stalk the mains flash on and the blue light illuminates.
Old Oct 26, 2006 | 07:53 PM
costina's Avatar
costina
Strange
This may help
II relay = dim dip try changing that one
X relay main beam
B rear fogs and dim dip try this one aswell
F Dipped beam headlights
Old Oct 26, 2006 | 07:59 PM
Paulo P's Avatar
Paulo P
I've changed number 2 but not the others. I'll grab them tomorrow and change them too. This is really winding me up now I just want the car on the road.
Thanks
Old Oct 26, 2006 | 08:04 PM
costina's Avatar
costina
good luck let us know how u get on
Old Oct 26, 2006 | 08:09 PM
Paulo P's Avatar
Paulo P
Thanks I'll report back tomorrow. I really hope this is it
Old Oct 27, 2006 | 07:44 AM
foreigneRS's Avatar
foreigneRS
Testing the future
also had this problem when i reshelled my cossie and put in lights from a 1.8. some headlights are wired differently internally to others and need an extra earth link inside. don't know the detail, my brother did it
Old Oct 27, 2006 | 04:23 PM
Paulo P's Avatar
Paulo P
All 4 relays changed and it still does exactly the same
Can you find out more details about how your brother fixed it please Nick?
Thanks
Old Oct 28, 2006 | 04:26 PM
Paulo P's Avatar
Paulo P
All earths that I can find have been cleaned. I've cleaned the ones behind the headlights, the one behind the clocks, the ones in both footwells and the one on the column but the fault is still there. One thing I did notice though is that the washers don't work either Could that be related?
I have seriously had enough now
Thanks
Old Oct 28, 2006 | 07:45 PM
costina's Avatar
costina
Wanna phone no Paul of a good auto electrician????
If so i will PM you his no
Old Oct 28, 2006 | 11:02 PM
Paulo P's Avatar
Paulo P
I have one coming on Tuedsday thanks but this is doing my head in Normally I'd be able to sort most faults on my own but this one has me stumped and I'm finding it annoying. I'm sure that this is connected to the washers not working now too, I'm sure they worked when I picked it up too.
Old Oct 29, 2006 | 06:30 PM
costina's Avatar
costina
Yes im sure there connected as lights need to on (dipped beam) to work
Old Oct 29, 2006 | 07:42 PM
coss1e2000's Avatar
coss1e2000
I had a similar problem on my saff. It turned out to be the multi plugs on the back of the lights.
Try moving the plug up and down a bit with lights on dipped beam and see if they come on.
Old Oct 30, 2006 | 08:56 AM
Paulo P's Avatar
Paulo P
I have had both plugs off but that is an interesting thought. I've often wondered if it's one of the light units that is faulty
Old Oct 30, 2006 | 05:28 PM
Paulo P's Avatar
Paulo P
A small update.
I've had an email from the previous owner of the car tonight with a photo of his fusebox. His fusebox has 2 small white relays on the right hand side but mine has brown ones in those locations
And these are what I have
Does anyone know the difference between these relays please?
My car is an 88 rear wheel drive model.
Thanks
Old Oct 31, 2006 | 08:51 AM
foreigneRS's Avatar
foreigneRS
Testing the future
no chance to find out paul, the car has been broken.
but it involved linking the earth in the multiplug that goes on the actual light unit to another pin in there as the headlight needed an earth that was not in the loom (must be 2 different lights, one with the earths linked interanlly and one not)
Old Oct 31, 2006 | 10:25 AM
Paulo P's Avatar
Paulo P
That's a shame. Thanks for replying though
Old Oct 31, 2006 | 10:32 PM
Paulo P's Avatar
Paulo P
Cleaned the earth on the drivers light again just to make sure but the fault is still there. I've also removed the dash and I can't see any earths that I missed and moving the loom makes no difference.
What on earth can I have missed?
Old Nov 1, 2006 | 09:10 AM
IANS2RST's Avatar
IANS2RST
check the connection on th fuse board itself. try moving the relays about & yes they should be white. just go down to your local scrap yard & there will besome in an old ford
Old Nov 1, 2006 | 10:30 PM
Paulo P's Avatar
Paulo P
I'm going to go to the scrappys Friday and bag some bits.
Tonight I decided it'd be a good idea to test the voltage at the dipped beam fuses in the fusebox and funnily enough I was seeing 6 volts at each There must be a fault somewhere in the fusebox
Old Dec 15, 2006 | 09:24 AM
IANS2RST's Avatar
IANS2RST
did u sort this eventually if so how as my new 2wd has done the same.
Old Dec 15, 2006 | 10:23 AM
davecosworth's Avatar
davecosworth
IM BACK
you have got the right stalk on there haven,t you i had a simallar problem when i used a stalk from a hatchback in the end i brought a new one for the sapphire.
JK12
33
Apr 26, 2021 12:09 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
