Mongoose exhausts...
Old Oct 25, 2006 | 01:51 PM
DazC's Avatar
DazC
Default Mongoose exhausts...
I have the 2.5" diameter with a 4" tail pipe one on my car. I used to like it but not it really irritates me. It's noisy, it drones and constantly drowns out any other sound including my stereo so I have to turn it right up to be able to hear anything. I've put up with it as the car isn't an every day car.
What are the other options bearing in mind that my car will be producing quite a bit of power next year? I'd still like to keep a larger diameter tail pipe if pos.
Old Oct 25, 2006 | 03:36 PM
Wazzzer's Avatar
Wazzzer
my Magnex isn't that loud and gives quite a nice note...
Old Oct 25, 2006 | 03:56 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Default Re: Mongoose exhausts...
add a silencer to the mongoose system
Old Oct 25, 2006 | 04:22 PM
DazC's Avatar
DazC
I'm just thinking that the 2.5" system might not be big enough diameter.
Old Oct 25, 2006 | 04:44 PM
SafeChav's Avatar
SafeChav
Ear muffs?
Headphones??
Dont really think theres any other options that wont restrict your power capabilites?
Old Oct 25, 2006 | 04:55 PM
DazC's Avatar
DazC
Well with reading about how quiet Martin Hadlands car is with a custom made pipe, i think it might be possible to reduce the noise without compromising power output too drasticly.
Old Oct 25, 2006 | 05:05 PM
Rick's Avatar
Rick
Daz, i remember Karl telling me that on Ollie's they went from a 2.5inch to a 3inch, and they didn't have to alter the map at all. Car wasn't exactly slow then, although it might eventually restrict - who knows.
The mongoose 3inch bore system with a 3.5inch tailpipe is suprisingly quiet - certainly quiter than the 2.5/4 system you have. If you really want to drop noise levels - then the power engineering exhaust, like Linsay and I have - made by cheesemans - is the one to go for. You heard (or didn't) Linsays on track.
It is as quiet as a factory car on the inside, but you get a nice burble on the outside. However, since i went to a T34 - it has got louder - not much - but still louder. The bigger exhaust housing has less silencing effect than the 0.36. I am actually now looking at adding another silencer to mine, which should make it near silent.
With a 4inch tailpipe, you are defo looking at another silencer.
Old Oct 25, 2006 | 05:07 PM
Rick's Avatar
Rick
Its down to the size and amount of silencers - if they straight through - they don't reduce flow
Old Oct 25, 2006 | 06:22 PM
DazC's Avatar
DazC
I do need to do something because I currently hate the noise it makes. You just can't cruize to any where and listen to your tunes without turning them up to over power the exhaust.
Not sure what I'm going to do yet as I need a different down pipe.
Old Oct 25, 2006 | 06:47 PM
Rick's Avatar
Rick
If i was doing it from scratch - and i may yet go down this route, i'd have a 3inch bore with 3inch tailpipe, A large rear silencer, and if possible 2 smaller silencers after the downpipe and before the fuel tank. If you look at the xr3i system - it has 3 boxes as std.
Old Oct 25, 2006 | 06:53 PM
SafeChav's Avatar
SafeChav
Xr3i's are loud as fuck and sound raspy!!!
Old Oct 25, 2006 | 07:02 PM
Rick's Avatar
Rick
lol, i know what u mean. No turbo to silence - and straight through system from the factory. They are ok inside - pretty quiet. The point is - 3 boxes
Old Oct 25, 2006 | 11:34 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Magnex exhaust if you want to keep it 2.5" bore, quiet and probably better made than a goose
or if you want bigger bore, 3" bore mongoose with the 3?4?" rolled in tailpipe. surprisingly very quiet as Rick says!
Old Oct 26, 2006 | 12:31 AM
EssexMikeSi's Avatar
EssexMikeSi
i love the noise of my scorpion system with 2.5inch bore. love the way it sits there droaning away. neighbours prob dont mind u lol
Old Oct 26, 2006 | 11:37 AM
DazC's Avatar
DazC
Been there, had a Scorpion and never again thanks. Another constant loud droning noise that gets on your tits if you're on the motorway for longer than 5 minutes.
So far an off the shelf Magnex looks like the best bet but it would apear that they are only 2.5"
I'm a little begrudging to get another Mongoose with past experiences.
Old Oct 26, 2006 | 12:18 PM
PaulieBoy's Avatar
PaulieBoy
my old S2 had a 3.5 inch mongoose tailpipe, in the boot under the standard carpet was a layer of thick wooly insulation type stuff cut out to the shape of the boot carpet, im sure this helped reduce the noise levels a bit
Old Oct 26, 2006 | 01:27 PM
SafeChav's Avatar
SafeChav
Nah.......even a standard one. My Orion 1.6i is loud, and thats got a standard exhaust! CVH's in general seem very loud in the exhaust department.
Old Oct 26, 2006 | 01:50 PM
DazC's Avatar
DazC
I've already got something like that under the carpet!!
Old Oct 26, 2006 | 04:39 PM
Andy_R's Avatar
Andy_R
3inch goose is the one to go for but its pricey...especiallly if your just after noise reduction
Old Oct 27, 2006 | 04:00 PM
Rick's Avatar
Rick
Daz, the off the sheld mongoose with 3inch bore and 3.5inch tail is quieter than the 2.5inch mangnex! PM me if ur intersted in one....
Old Oct 27, 2006 | 06:39 PM
DazC's Avatar
DazC
You have PM Rick.
Old Oct 28, 2006 | 11:24 PM
Rick's Avatar
Rick
Old Oct 29, 2006 | 11:15 AM
Dan's Avatar
Dan
Mine is exactly the same Daz, I drive my car even less than you and for no length of time either so I can put up with it! But can certainly sypmathise with you!
Old Oct 29, 2006 | 11:28 AM
DazC's Avatar
DazC
I only drive mine to Blackpool and back on a Sunday evening as long as it's dry! It irritates me within 30 seconds of getting on the motorway!!
JK12
33
Apr 26, 2021 12:09 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
A.t.p
Sep 29, 2015 05:04 PM
