boost settings
Old Oct 25, 2006 | 12:07 PM
sy.rst's Avatar
sy.rst
Default boost settings
iv just fitted a new -31 actuator on my s2, the boost gauage peaks at 12 then holds 10 and drops down to 8psi.flat out in third. have i got a boost leak or is this normal. should i have the boost set higher,im useing standard intercooler,the ecu has been chiped.when i brought the car the guy said it wos running 12psi boost, should i set it 2 peak bout 15 then hold 12. I live on the isle of wight so have no exsess to a rolling road with out traveling to mainland.any help would be appreciated.
Old Oct 25, 2006 | 08:00 PM
Rick's Avatar
Rick
pretty normal. Yout could set it to hold 12, even 14, but it's not a wise move unless you can get the fuelling checked.
Old Oct 27, 2006 | 03:16 PM
mattrst90spec's Avatar
mattrst90spec
Having a standard intercooler dont help, when i had standard one the boost used to drop away like you are saying, ive since fitted a front mounted pro-alloy with twin fans & it peaks at 16psi & holds 14psi & it dont drop at all, it stays bang on 14psi.
Matt
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
