BRAKE PROBLEM HELP!!!!!
Old Oct 25, 2006 | 11:35 AM
tank1987's Avatar
tank1987
Default BRAKE PROBLEM HELP!!!!!
hi guys need help
lost brake pressure on my 3dr the other day on way to work it's running a pinto with non abs,bleed all brakes no change, can anyone suggest any help
thank you
Old Oct 25, 2006 | 04:21 PM
tank1987's Avatar
tank1987
can anyone help fairly urgent
Old Oct 25, 2006 | 04:24 PM
Moonie's Avatar
Moonie
When you say you have lost brake pressure do you mean the pedal is going to the floor (fluid leak or air in system) or the pedal is hard to press (lack of servo assistance)?
Old Oct 25, 2006 | 06:45 PM
tank1987's Avatar
tank1987
thank you for replying
yeah the pedal is going to the floor where as before it was alot higher and the brake fluid tank was empty , we have bleed all brake but only made very slight difference could it be master cylinder or servo
thanks for any help
Old Oct 25, 2006 | 06:49 PM
Spiky's Avatar
Spiky
so it goes all the way to the bottom and you have lost fluid???
check all the calipers for a leak
check all the joints as these might have a leak, or signs of a leak
Old Oct 26, 2006 | 12:22 PM
tank1987's Avatar
tank1987
no sign of leaks at all had it up on ramp thats y im lost
Old Oct 26, 2006 | 12:23 PM
SapphyMike's Avatar
SapphyMike
servo's probabaly failed.
Old Oct 26, 2006 | 12:25 PM
Alvyn's Avatar
Alvyn
as above the fluid most probably is inside the servo!
Old Oct 26, 2006 | 12:27 PM
Spiky's Avatar
Spiky
so have you lost fluid from the resovour
Old Oct 26, 2006 | 01:41 PM
tank1987's Avatar
tank1987
yes initially but stay at same level now
Old Oct 26, 2006 | 02:23 PM
ballin's Avatar
ballin
servo gone mate
Old Oct 27, 2006 | 08:08 PM
tank1987's Avatar
tank1987
best place to get one
Old Oct 28, 2006 | 12:49 PM
Mo_MK4scort's Avatar
Mo_MK4scort
Ive phoned round and manage to get one from a spares place mate
Old Oct 30, 2006 | 05:42 PM
tank1987's Avatar
tank1987
cheers for all help
Old Oct 30, 2006 | 05:52 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it may be that the m/c is leaking inside the servo
make sure you check it all out because if it's the m/c you'll be needing another servo in a few hours time
Old Oct 30, 2006 | 06:11 PM
Moose 130's Avatar
Moose 130
if you pump the pedal with the car not running, hold it when it goes hard, start the car, the pedal should drop slightly as teh servo works.
if it doesn't your servo is screwed.
pedal creeping to the floor is signs the master cylinder has gone.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
