intercooler help
not ford but hopefully someone will know....i have bought a smart car intercooler for my classic mini turbo and the pipes going in and out are 44mm and 46mm...question is which one is inlet and outlet???
regards mark
regards mark
regards mark
regards mark
regards mark
regards mark
mark
Are you plumbing in a act sensor at all? If so trial and error it.
Also where are you looking to locate it Mark? As I said before the guy up the road from me is doing something similar but to a van. Its off been painted at the moment, but it would be interesting to know how you've done it as they always seem to run a bit too hot ....
2nd picture on second page nath is where i hope to put it...i need to know before i attempt a install so as to route pipes correctly.... http://www.photobucket.com/albums/0903/mark4765/mini/
regards mark
regards mark
regards mark
regards mark
WWW.PROALLOY.CO.UK
maybe it doesnt matter.... but surely they would make both pipes the same diameter if that was the case
mark
mark
www.proalloy.co.uk
if you need any pipe work give me a shout
Looks good though!
