cossie wont start
Old Oct 24, 2006 | 07:19 AM
MARKYMARKONE's Avatar
MARKYMARKONE
Default cossie wont start
hi all
i went to go off to work this morning started the car run fine for about 2mins then cut out , problem is no it want start all its doing is turning over.
what is suspect in the case usally?
all help would be great
cheers
mark
Old Oct 24, 2006 | 06:47 PM
anthony4773's Avatar
anthony4773
have you tried the fuel cut off switch, they can fail causing the fuel to stop.on a sierra its located under the spare wheel in the boot and can just be bridged out to test it
Old Oct 24, 2006 | 07:52 PM
MARKYMARKONE
ni antony
thanks for the reply, found it to be a dodgy ht lead for some reason it must have been sparking out where it fits on the dissy cap and become stuck evening trying to pull it out it snapped of.
so it had replaced phase sensor, rotor arm, cap, leads and a coil, as this was found to be givin a spark 1 min and not the other.
so fingers crossed it will be ok now
thanks
mark
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Alun Gregory
Sep 6, 2015 09:40 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
