Gearbox on its way out?
Old Oct 23, 2006 | 10:15 PM
gregors's Avatar
gregors
Default Gearbox on its way out?
When driving at 30mph and dropping down in to 2nd to come to a stop when lifting the clutch a weird whine/squeel happens for a few seconds then goes....is this a sign of the gearbox on its way out?
Old Oct 24, 2006 | 05:08 PM
SafeChav's Avatar
SafeChav
What you've written isn't very easy to understand.
Squealing is usually a thrust bearing about to destroy itself though....
Old Oct 24, 2006 | 06:20 PM
gregors's Avatar
gregors
well when im driving along, say in 3rd gear and coming to a junction i drop it into 2nd gear. As i lift the clutch back in, a high pitched noise is heard which lasts for around 2 seconds. It does not make the noise at any other time other than when engine braking.
Old Oct 24, 2006 | 06:39 PM
SafeChav's Avatar
SafeChav
In that case it could be the clutch plate itself. When the clutch plate is worn right down to the rivets they can make this noise.
I'd say its the clutch either way. How old is it? Hard to pull off and/or select gears at all?
Old Oct 26, 2006 | 08:48 PM
gregors's Avatar
gregors
The car selects gears fine and pulls fine. however when im accelerating and i come off the gas it makes the noise and if i put the clutch pedle down it sounds like something spinning then stops. if i then raise the pedle it comes in again but as soon as i put on the gas the noise stops??
When chaing gear, for example going from 3rd to 2nd, when the clutch is down and i select 2nd, the noise happens for a very short period of time like a little blip, then goes. If i then raise the clutch to engage into 2nd gear i get the noise back.
Any idea? its really starting to annoy me that i cant work out what it could be
cheers
Old Oct 27, 2006 | 07:15 AM
Alvyn's Avatar
Alvyn
Is the car a front wheel drive? if so I'd say what's been said above is the problem rather than the box itself!
ps how old is the clutch?
Old Oct 27, 2006 | 06:58 PM
gregors's Avatar
gregors
clutch age is unknown, had the car for about 2 months now.
Yeah its a s2 rst. How do you mean the above is the problem rather than the box? what do u think it could be?
Old Oct 28, 2006 | 11:43 AM
gregors's Avatar
gregors
clutch has now gone and gearbox is selecting 2 gears at once and i cant pull it out of gear....time for new clutch and gbox i think
as i have a 1.8 bottom end what clutch do i use? a 1.8 clutch or still a rst clutch?
Old Oct 28, 2006 | 01:40 PM
SafeChav's Avatar
SafeChav
How does it select 2 gears at a time thats virtually impossible???
You just want a 220mm clutch they all share the same fitment.
Old Oct 28, 2006 | 01:44 PM
gregors's Avatar
gregors
It just sounds like its mashing all the gears together :S going to replace the clutch first see if it fixes it, if not then new box.
Old Oct 28, 2006 | 01:49 PM
fatboy billy's Avatar
fatboy billy
from what you said earlier sounds like the clutch to me id go get an rs clutch and try that if it isnt you know its the box and you will hav e to replace it
Old Oct 28, 2006 | 01:54 PM
SafeChav's Avatar
SafeChav
I expect, from what you have said, the springs on the pressure plate have snapped, and its subsequently destroyed the thrust bearing (the squeaking was the bearing being slowly destroyed) and now you are crunching gears because the clutch isn't working.
If you start the car in gear can you stop the car by pushing the clutch in?(P.S trying this could lead to brown pants )
Old Oct 28, 2006 | 03:05 PM
gregors's Avatar
gregors
spot on, apart from im not gonna try it lol. just tried driving it again to try and get more info on it and well the clutch went up in smoke lol
Old Oct 28, 2006 | 03:15 PM
SafeChav's Avatar
SafeChav
I bet the springs have snapped and destroyed the bearing.
Had the clutch been juddering/hard to pull off/stiff pedal?
Old Oct 28, 2006 | 03:16 PM
gregors's Avatar
gregors
not really, had a slight judder in reverse mate
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
