4x4 COSSIE WOBBLE
Old Oct 23, 2006 | 07:29 PM
cameron2's Avatar
cameron2
Default 4x4 COSSIE WOBBLE
MY STEERING WHEEL WOBBLES ON MY SAFF WHEN I GO OVER 60. IT DOESNT FEEL LIKE A WHEEL BALANCE WOBBLE EITHER, ANY IDEAS?
Old Oct 24, 2006 | 03:48 PM
JohnP001's Avatar
JohnP001
I have read many threads now regarding wheel wobbles, but no one seems to have posted a solution.
I’m trying to solve my wheel wobble on my Escort Cosworth as well, but to no avail.
Maybe this is of some help to you, if I tell you what I’ve done so far: -
My problems manifested themselves after fitting New Koni Shocks and Ahmed Bayjoo springs.
My first thought was wheel balancing, and as I needed new tyres, I fitted new tyres onto refurbished rims and had them balanced. No difference.
Fitted new wheel bearings on both sides, as one side was very worn. No difference, which did surprise me.
Fitted new steering rack. No difference.
Fitted new steering coupling. No difference.
Fitted new track control arms with new Powerflex bushes, inner and ARB. No difference.
Fitted new Trilobe bearings both sides. No difference.
Fitted longer drive shaft on left hand side. No difference.
Fitted new top mount shock absorber rubbers. No difference.
Checked bearing on transfer shaft from diff to offside drive shaft. No play.
Checked universal joints on prop shaft from transfer case to front diff. No play.
I think I’ve changed everything that can be changed, and the wobble is still there.
So I’m open to suggestions as well.
John
Old Oct 24, 2006 | 04:31 PM
cameron2's Avatar
cameron2
Mine developed when i put new koni springs and shocks on aswell!
Iam beginning to think i have some kind of driveshaft trouble!
My o/s driveshaft had a fucked bearing in it and was "repaired" by the garage when they fitted the shocks.
Anyone agree????????
Old Oct 24, 2006 | 05:15 PM
Ben26's Avatar
Ben26
just make sure that the wheels have the correct spiggot rings in the back of them
i know for a fact that without them the wheels can shake like a fucker when u go to over 50 / 60 mph
Ben
Old Oct 24, 2006 | 06:08 PM
JohnP001's Avatar
JohnP001
Just to add, I've checked my CV joints, and there's no up and down movement. Also checked tie rod ends, and they're stiff, with no play.
Just checked spiggot rings, and wheels fit snug on hub, although I am running a 6 mm spacer to fit over the calipers, this wasn't a problem before I fitted the Konis and springs. (Had AVO's before.)
Old Oct 24, 2006 | 06:21 PM
cameron2's Avatar
cameron2
Mine was ok before the konis went on!
Might be time to drop koni a quick email and see what the fuck is going on!
Old Oct 24, 2006 | 06:52 PM
JohnP001's Avatar
JohnP001
I've just changed the rear wheels to the front, and the fronts to the rear, and taken it for a quick spin, to see if that changed anything. Wobble still there. I'm at my wits end now, as I don't know what else to do, other that buy a different suspension setup, and bin the Konis and Ahmed Bayjoo springs......
Old Oct 25, 2006 | 04:50 PM
Fozy's Avatar
Fozy
I had this issue on my Escort. What it took for me was to get the wheels balanced again....but this time using a seriously accurate wheel balancer. Non of the "I'll balance them for a tenner mate" kind of garages and even the big guns couldn't balance them so I used our super special one at work that we use for vibration assessment.
In discussing with a mate from our wheels and tyre dept. us "boy racers" (hes and old chap) are playing with the geometry to much. adding spacers, changing profiles of tyres and lowering the car upsets them.
Another area is that hubs can play a part to. It appears as wheel wobble but its actally the warped hubs effect on wheel rotation. Luckily for me i was ok, but its a good check. Get our you DTI gauge and just check if there is any run out/float/distortion.
Best of luck as I know how frustrating it can be.
Old Oct 25, 2006 | 09:29 PM
JohnP001's Avatar
JohnP001
Good point. Will get my gauges out and measure the hub run out.
Old Oct 26, 2006 | 08:21 PM
cameron2's Avatar
cameron2
How did you get on with the gauges?
Old Oct 26, 2006 | 09:14 PM
cameron2's Avatar
cameron2
How about the steering column bush?
Old Oct 26, 2006 | 09:19 PM
Rsailor's Avatar
Rsailor
Get them re-balanced. I fu**ed up 2 wheels on a van. twice. The balancer at work is crap. Its a bas*ard to get the wheel straight on it.
Also tracking and make sure the tyres have the right pressure in them as this can screw it up.
Old Oct 27, 2006 | 08:24 AM
JohnP001's Avatar
JohnP001
I don't have time during the week to work on my car. I'll be looking at it on the weekend. I'll check the steering bush while I'm at it. Something else I'm going to try is rotate the brake disks on the hub. I know I removed these when I replaced the suspension. I did mark them when they came off, but might be worth a try.
Old Oct 27, 2006 | 08:29 AM
JohnP001's Avatar
JohnP001
Tracking has been done, after I put the new steering rack in. Tyre pressures are correct. (2.2 front and 2.4 back when cold) Might have them rebalanced if the above doesn't work.
Old Nov 11, 2006 | 05:55 PM
JohnP001's Avatar
JohnP001
I’ve finally got around to measuring my hubs and discs. Cleaned them up, so there was no mistake in the measurements. The run out on one hub was 0.03mm and the other 0.02mm. (The later being the new hub just fitted.) The run out on the discs, when fitted to the hubs, were 0.06mm for one side and 0.08mm on the other. (Therefore within tolerance according to my manual. Disc run out should be less than 0.1mm) These are Tarox discs, and are only on their second set of pads, so are fairly new. I rotated the discs 180 degrees on the studs, and then took it out for another test drive, and no difference. I did a hard brake from about 110mph to stand still, and the car tracked true, and no pulsating on the brake pedal. So the discs are not the problem.
When the gauge was on the hub I tried to move the hub up and down to check for play, and there was no movement on the gauge.
I’m now convinced that the shocks are the problem, as the problem only arose after they were fitted. I’m going to buy some second hand shocks, and try them out to see if the Konis are the problem.
Will post my findings when done.
John
Old Nov 13, 2006 | 09:16 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
its normally an inner cv joint problem that gives wobble over 60, over the last year mine has started to develop a wobble so im just about to repalce both inner and outer joints.
Old Nov 13, 2006 | 09:24 AM
JohnP001's Avatar
JohnP001
I've replaced the inner ones, so might just replace the outers to see if that solves the problem.
Old Nov 13, 2006 | 09:26 AM
JTECH James
Passion for Fords!
i had a wobble on my old saff and it turned out to be an outer joint was seizing up.....
Old Nov 13, 2006 | 11:08 AM
JohnP001's Avatar
JohnP001
Got the outer CV joints on order now, and will be changing them on the weekend. Hope to hell this solves the issue.
Old Nov 19, 2006 | 10:25 AM
JohnP001's Avatar
JohnP001
Changed both the outer CV joints, and the wheel wobble has gone.
The steering and front end feels fantastic. So positive and true. Well I should think so, seeing that I’ve changed every thing that could be changed.
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
mpilk
Sep 27, 2015 09:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
