Buying a 2wd, problems and rust area's to look for?
As above please, looking at one over the weekend, seems a pretty good car and the guy is honest and upfront which is always good
But as we know they all can hide their problems...
i know its under the carpet but the gearbox tunnel rotts around where the plastic heater thing that goes under the seat screws in the floor and the front seat mountings. thats the rear of the front seats. also around the grills in the front foot wells as these are just covered with sound deadening and water can get in through the jack points in the front and look like they rot under the seam sealer.
Just walk away and go buy something German
Check all the above mate ie, rear chassis rails, inners/outer sills.
Check front Suspension turrets as they can be cracked.
Check boot floor to see if its been rear ended at any point.
Check to see if the front brake lines are crushed as people jack close to them.
Just do all the usual checks mate....Good luck with the search
Cheers peeps, we'll just have to give it a thorough once over then!
I hope your prepared for it then!
Originally Posted by loader5710
Everywhere, its a sierra
borboyous
Aug 22, 2015 11:17 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
adam151082
Aug 11, 2015 04:50 PM
