erst exhaust flange bracket
anyone got or know where i can get the flange bracket that joins turbo to d/pipe, cant find one anywhere, ford will only sell it with d/pipe
cheers mate
i think i need to come down see you anyway, you fab stuff so im told, what im after is an adaptor so i can use 3i inlet on efi if this is possible, just so i can use 16i rocker, do you have anything like that, also whats best time to come over and where exactly are you, cheers, paul
Im in upminster in essex pal. There every day of the week
07050 133596
The Conversion plate needed to fit and EFi inlet to an MFi head is off the shelf item pal.
Come over and pick up the few free bits you want an you can ask and see what you like
Regards
Jano
07050 133596
Regards
Jano
Mc5506
Oct 5, 2015 09:57 PM
