my radiator problem
Old Oct 17, 2006 | 07:21 PM
rspower586's Avatar
rspower586
Default my radiator problem
i have a s2 rs turbo i am running about 200bhp and i keep cracking my radiators any ideas why?
Old Oct 17, 2006 | 08:42 PM
Turbo-Beal's Avatar
Turbo-Beal
Where is it cracking?
Old Oct 17, 2006 | 09:24 PM
PeterD's Avatar
PeterD
What kind of intercooler and rad setup you got fella?
Are you running them sandwiched together or fans between, they could be rubbing.
Old Oct 19, 2006 | 05:50 PM
rspower586's Avatar
rspower586
its a standard radiator with a standard fan and i have a pace intecooler. the first time round when it was leaking this was because the intercooler was rubbing against the rad i have sorted that out and got the radiator re cored now a month down the line i think the plastic end cap has cracked
Old Oct 19, 2006 | 07:59 PM
Turbo-Beal's Avatar
Turbo-Beal
Has it split at one of the hose connections? You could have overtightend a jublee clip and cracked it when installing it. If its nothing obvious that you have done when installing it can you take it back to the place you had it recored? Would have thought they would put it right under guarantee if its just gone without any obvious reason why.
Old Oct 20, 2006 | 10:12 AM
rspower586's Avatar
rspower586
i have taken it back to the place that i got it recored at they said that they aint sure why it cracked the way it did they are gonna get another radiator for me because mine is apparently unrepairable hopefully it wont be long till i get my car back on the road missing it already
Old Oct 20, 2006 | 11:53 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Have you had the head gasket checked?
DAZZER
Sep 30, 2015 08:43 PM
