Another problem lol , brakes this time
Old Oct 16, 2006 | 07:54 PM
rabmc's Avatar
rabmc
Default Another problem lol , brakes this time
Me again troops
Right have another niggly problem , when i start car and drive for 5 mins brakes are fine then suddenly go realy hard ! And need to really press down on them to stop it , and continues like this till next journey
My right legs soo sore honest , any help here really is appreciated , this cant go on man
Old Oct 16, 2006 | 08:08 PM
STUCOS's Avatar
STUCOS
Sounds like abs pump faulty or is losing it,s feed,maybe due to plug heating up from turbo heat,check wires/plug at abs pump
cheeRS stu
Old Oct 16, 2006 | 08:15 PM
rabmc's Avatar
rabmc
Cheers stu , im on to that first thing tomorrow , cheers
Old Oct 17, 2006 | 06:48 PM
dojj's Avatar
dojj
Resident Wrestling Legend
pressure switch seems to either be working overtime or not working properly when it's turning off time
rock hard pedal = stop the car and don't drive it anymore time
does the handbrake light ocme on at the same time?
Old Oct 17, 2006 | 07:37 PM
rabmc's Avatar
rabmc
No mate , no light ?
Was out i there and it was fone , but iL go out againa nd it will probably go hard
Working late tonight so doidnt have a chance to investigate any further
Old Oct 24, 2006 | 07:08 PM
rabmc's Avatar
rabmc
bttt
Had a good ook at this , and to me everyrhing looks ok
Any ideas , would it defo be this abs pump ? is this located in th left of engine bay sort of next to turbo ?
Think it could just be knackered guys ? Im not down with my brakes lol
Old Oct 24, 2006 | 07:10 PM
rapidcossie's Avatar
rapidcossie
its defo a fault with the abs rab as mine faild completely last week.
check the fuse under the dash under where the ecu lives...
Old Oct 24, 2006 | 07:13 PM
rabmc's Avatar
rabmc
Old Oct 24, 2006 | 08:25 PM
dojj's Avatar
dojj
the pump lives on the turbo side of the engine bay
the other side is the valve block which does other stuff
if the pedal is going hard then it's the pump side of things thats going screwy, normally a failure of the pressure switch to turn off after the required 180bar has been reached
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
saph in dorset
Aug 14, 2015 10:10 AM
Sjieter
Aug 5, 2015 09:47 PM
