how long will a wideband lambda sensor last
Old Oct 15, 2006 | 07:40 PM
leecavturbo's Avatar
leecavturbo
Default how long will a wideband lambda sensor last
if plumbed in working and car used daily as normal?
sure i read they won't last that long?
1mth? 1 yr? 10yrs?
Old Oct 16, 2006 | 07:18 AM
Garage19's Avatar
Garage19
All depends how what sort of fuel you run and how rich you run.
Certain fuel additives kill em quicker and so do rich mixtures. If you seal you exhaust with something that contains silicone they will dye very fast!
I would say 3 months of driving in a rich car or 30k miles in a VW golf 1.8t which is where the bosch one is used as an OE part.
Old Oct 16, 2006 | 08:20 AM
Tim's Avatar
Tim
seem to get around 8 months out of mine
Old Oct 16, 2006 | 05:04 PM
leecavturbo
is that with the cheap one? there's 2 mainly available iirc.
ones Ł60-70 and the other Ł200
does the "better" one last longer too?
Old Oct 16, 2006 | 05:06 PM
Tim's Avatar
Tim
with the cheap ones pal the others last no diff maybe less,i run the same one as daz does at nobles.
Old Oct 16, 2006 | 05:11 PM
ECU Monitor Enthusiast
According to my Bosch literature, they last 500 hours average !
Mine lasted about 3 hours as I used ALS on it
Old Oct 16, 2006 | 05:19 PM
sas's Avatar
sas
should be good!
My inovate one has been on and working now for 9 months.
mjonathan24
Oct 29, 2015 10:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
