gear box oil??
Old Oct 13, 2006 | 03:32 PM
SWIFTY's Avatar
SWIFTY
Default gear box oil??
what would be the right oil to put in a rwd 1989 gear box???
thanks
Old Oct 13, 2006 | 06:49 PM
saphc05's Avatar
saphc05
i use atf(auto transmission fluid) as the oil in the manual made my box whine a little has been in for about 12 months with no noises/problems
Old Oct 18, 2006 | 10:07 PM
radiant red's Avatar
radiant red
atf is a lot thinner thought this would be bad
Old Oct 19, 2006 | 05:03 AM
2001ode's Avatar
2001ode
Hi
2wd gear box oil finis code is : 5 014 519 (1 litre)
SQM2C 9010-A (Ford spec) Dexron BA
(same for power steering)
Regards
Claude
Old Oct 19, 2006 | 10:13 AM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Originally Posted by 2001ode
Hi
Regards
Claude
I did not know they used the same in the power steering as in the gearbox. Im just going to change my PAS fluid, is this the correct fluid?? ^^^
Bruce
Old Oct 19, 2006 | 10:54 AM
saphc05's Avatar
saphc05
sorry for the confusion its actually called hydraulic fluid used in auto boxes and pas systems red in colour cant remember finis number. a friend who's a service tech for tvr also recommends using this in t5 boxes
Old Oct 20, 2006 | 12:57 PM
oilman's Avatar
oilman
The T5 was originally run on ATF fluid, well a modified version of.
It is not uncommon for manual gearboxes to use an ATF. If you want a really good one have a look at the Amsoil Synthetic ATF.
http://www.opieoils.co.uk
Guy.
Rizlablue
Sep 6, 2015 09:58 AM
Adam Graham
Sep 6, 2015 06:04 AM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
