MK5 LOCK SET
Old Oct 12, 2006 | 07:18 PM
Turbo-Beal's Avatar
Turbo-Beal
Default MK5 LOCK SET
Does anyone know if a escort mk5 lock set will fit a mk4? If not a straight swap does anyone know if they could be made to fit using the old mk4 lock set?
Old Oct 13, 2006 | 05:39 PM
DAZZER's Avatar
DAZZER
Default mk 5 locks
Hi the lock itself will fit but the lever is different,you may be able to make it fit but not sure.
Old Oct 13, 2006 | 05:41 PM
Turbo-Beal's Avatar
Turbo-Beal
Cheers m8 ill give it a try
Old Oct 20, 2006 | 07:49 PM
Turbo-Beal's Avatar
Turbo-Beal
Got my new lock set the other day and iv started doing the little mods requied to get the front to fit properly.
As you can see from the pics iv started shaping the end of one of the arms. Iv mesured everything up and apart fom drilling the hole i should only need to make a small spacer up for the inside of the door to hold the lock firmly in place. I havnt yet checked to see if the rear boot and ignition lock is diffrent but im hoping they are the same. Ill do an update on how it goes for future use
Old Oct 20, 2006 | 08:02 PM
scottbrown's Avatar
scottbrown
why did you want to use mk5 instead of mk4?
Is it better/stronger?
genuinely interested.
cheers
Old Oct 21, 2006 | 09:34 AM
Turbo-Beal's Avatar
Turbo-Beal
The only reason i went for a mk5 lockset is that i got it real cheap. Im not even shure if you can still buy a new mk4 lock set as iv never seen any for sale.
The front door locks should be stronger though as im replacing the plastic arms for metal ones.
Old Oct 21, 2006 | 12:18 PM
antony215's Avatar
antony215
Escort Rs Turbo
The boot lock won't fit mate the mk 4 is a push button type mk 5 work's off of the key/switch
Old Oct 21, 2006 | 04:14 PM
Turbo-Beal's Avatar
Turbo-Beal
On the rear im hoping to change the new core over to the old lock im gonna have a go tonight so ill see if it can be done.
Old Oct 21, 2006 | 05:07 PM
antony215's Avatar
antony215
Escort Rs Turbo
Dont think you can mate the rear one's are a sealed unit unlike the door one's where you can take them apart.
Old Oct 21, 2006 | 07:34 PM
Turbo-Beal's Avatar
Turbo-Beal
Well i can say for definate that you can cange the core of the mk5 rear boot lock into the mk4 lock. See pics below how i did it
The core removed from the old lock by removing two c clips from the rear
The new core beside the old lock. Had to pry the front cover off the mk5 lock to get at the core
Putting the first c clip back into place
Spring, lever and last c clip laid out ready to put back together
All done
Old Oct 21, 2006 | 10:12 PM
antony215's Avatar
antony215
Escort Rs Turbo
I thought you were just gonig to try and change the barrel over not pull it apart and change all the inside's over fair play to you
Old Oct 21, 2006 | 10:14 PM
Turbo-Beal's Avatar
Turbo-Beal
Where theres a will there is a way
Old Feb 1, 2007 | 01:56 PM
SafeChav's Avatar
SafeChav
Indeed
rex647
Mar 6, 2022 06:20 AM
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
